Post Info TOPIC: tingles from the van
Waranty or not Graeme, I'd be taking it back to the yard and making them fix it.  They sold it to you as a good, working, road worthy vehicle.....I am sure you did not get a big discount because you were buying a faulty van.
I would think they'd have a duty of care to say the least.....especially where the 'tingles' are concerned.
Push the roadworthy issue as well. Make a lot of noise if they are not compliant.
-- Edited by Boroma577 on Sunday 4th of March 2012 10:36:53 AM
Destination: AUSTRALIA....... all over.
Yes, duty of care. Roadworthy, electrical compliance. Neglect by workshop on brake issue. Go back to the dealer and push REALLLY hard for no cost retification. If they wont come to the party, hitch the van up and tow it back to the yard, block the entry and then call the local paper. They love these stories. Write up the facts of the matters in dispute, photo copy a couple of dozen copies, paste some on the van , and hand out the rest to any prospective buyers in the yard. It will work!!!!!!!!!!!!
PS.....make sure that there is an RCD fitted to the van
-- Edited by Bent Axle Bob on Sunday 4th of March 2012 11:15:36 AM
Take only your memories, leave only your footprints
hi guys hows it going out there in grey land lol.
well we got the new home and were stoked so is our border trailer trash as he went from a 13 ft er to a 21 fter he didnt want to but we forced him to as he is my best m8 he didnt want to be the first to sleep in it but being second hand we said its ok .
couple of isues not so much with the van but with theyard .
now a second hand van dosnt have warrenty .thats ok i think
first isue after having a roadworthy and even after telling the workshop guy about the wire from the chasie to the brakes was broken it wasnt fixed . so how good did the roadworthy guy look . i will pull all the drums of and check the brakes my self .
second is the compliance plate weights are different to the rego papers. and they said we mite have to take it to the transport dep . well the jokes on them it was sold to us as this weight and its got that weight well its up to them to rectify
now this one alludes me its got tingles from the van when hooked up to 240 v just like a washing machine does sometimes . i just thought it mite be the earth to the house so i will get that checked to . or is there something that could be a common thing in the van.
apart from those couple of things were extatic it tows perfect and looks a million dollars (well to us any ways )  over time we will do our thing to it and use it as much as we can before the permanent life change happens .
PS dellas doing ok were going for a meeting with radiolagy docs monday will get her to updat that report mon nite.
dibs
gdyble
Geeze Graeme.  I sure hope that can all be rectified without any extra expense to you.   Don't like the sound of it myself.
I'l be thinking of you both tomorrow.
That's a shocking experience Graeme.
Sorry all, someone was eventually going to say it.
A tingle could quickly turn to a deadly zap.
Get it seen to immediately.
OJ
Tingles? Not good Graham, be careful! Mr D suggested keep the 240volts off till this is solved.
Have a wonderful time with it when you get these glitches sorted... and yes I agree, get pushy with the person you bought it from.
Cheers,  Gerty. ... at home
Bear50 wrote:
It's not unusual for 6 volt batteries to be connected in parralel as you can get more amp hours than for more 12 volt batteries connected in serries.
I believe they may be cheaper also but not sure.
 Wrong way round mate! wink
Two 6v batteries in series will give you 12v. Two 12v batteries in parallel will still give you only 12v but will give you the total amphour capacity of each battery, ie two 100ah bateries will give you a total of 200ah
In the case of series connected 6v batteries each battery would need to be 200 ah each to give you a total of 200 ah. This is my preferred option if it is practical to do so. A 6volt 200ah would be a similar physical size to a 12v 100ah but check this out as this may vary between brands.
A 12volt battery consists of six 2 volt cells connected in series to get a total of 12 volts, that's why there are 6 caps on a 12v wet battery, one for each cell. Two 6v batteries in series also consists of six (three in each battery) cells connected in series, and therefore is electically identical to a single 12v battery.
Series connection means that there is only one link between the two batteries connecting the positive of one to the negative of the other and the positive and negative wires going to the system are connected to unused positive and negative terminals of the batteries.
In parallel connection the two positive terminals are connected to each other and likewise the two negative terminals.
Lets not hijack this thread into a debate about series versus parallel, I'm just explaining the difference between the two.
-- Edited by jimricho on Sunday 4th of March 2012 07:00:25 PM
Merda tauris scientia vincit
The Master
Someone else on here was having trouble with tingles when connected to 240. It turned out to be the electrical cord she was using. Was faulty, she bought a new one and had no more problems.
I'm not sure who it was but may have been in the Techies Corner.
Happy Wanderer
Don't worry, Be Happy!
JRH
dibs
 Graeme before you go to the dealer re the tingle why not try and hook up the power from a friends house and if the tingle persists then it is the van at fault, if it does not persist then get your house earth checked out.
Did your previous van get the tingles when hooked up to the power at your place, if not then the new van definitely sounds suss.
Good to hear Dell is doing OK, our thoughts and prayers are with you both continually.
If I don't get there today, I'll get there tomorrow or the day after.
John & Irona..........Rockingham Western Australia
how do you hook a caravan to normal house power, i thought they were different plugs in the walls?
i know dad had to get a different plug in the wall to match the 15 amp lead to the van or am i wrong in that
other wise we would have used a little piggy back lead some one gave us..
The Drewsterz my band site
Milo Online  my personal site
Master (of Mischief)
DO NOT PLUG INTO 240 POWER
Phone ACCC on this number 1300 302 502 they only advise what you should be doing.
I think you should take it back to the dealer and tell them you want it fixed NOW, if not tell them you will have to contact the ACCC, they usually do the right thing if they think you know your statutory rights.
Extract from 'Your Consumer Rights' info sheet: No matter what a retailer, supplier or manufacturer says to you or gives you in writing, your statutory rights cannot be taken away.
YOU MUST READ THESE PAGES BELOW BEFORE YOU GO FURTHER
http://www.accc.gov.au/content/index.phtml/itemId/1023610
http://www.accc.gov.au/content/index.phtml/itemId/1024824#acccWorkflowWizard1Path:1
http://www.accc.gov.au/content/index.phtml/itemId/1026241
Please...please...please, Graeme, Listen to Wombat..... PLEASE!!!!! This is not good.
 I just hope he see's my post soon
i dont remember getting a tingle from the mobile home but i didnt crawl over it like i have with the van as its new to me i was just looking at things when i felt it. we tried a different lead and i even tryed the stainless tub in the laundry but nothing.just went up and tested leads they come up to scratch so im guna put it in the hands of the cvan yard and if they dont want to play the game i mite have to ring consumer affairs (my dad tought me that).
also put multie meter on the batteries and found them only to be 6 volt 200 amp deep cycle bloody great heavy things .
update soon
dibs
gdyble
JRH
update soon
dibs
 Graeme it would be circumspect to have a few words with the dealer and see what you can organise, I was a bit remiss in suggesting that you try and hook up at a neighbour's house and for that I apologise.
thanks wombat i did see that i went up before and took the lead out and told trailer trash not to plug it back in till its sorted hes smart he wont replug it .thats how i found out the batteries were only 6 volt .lol
dibs
gdyble
dibs
 ACCC will tell you to, go to the dealer in the first instance, IF they will not play they will then advise you to put your concerns in writing to the dealer and allow about 14 days for a reply, I suggest you register the letter.
Let's all hope you do not have to do the above and the dealer see's that you know what you are talking about and does the repairs free of charge.
Keeping my fingers crossed for you both.
Good to hear my mate Della is going ok.
Brian and Lorna.
4.2 Patrol & 19.5 Kedron TE.
No matter what or where you park your van it should not "tingle". There's electricity on the loose there somewhere. It needs to be examined by the agent you bought it from.
There is a short warranty on these things, and it's your money, you are entitled to get what you paid for in good order and safe condition.
While a caravan is simply an aluminium box with staples and pop rivets, you will be depending on it for safe towing and shelter when parked.
Please investigate the problems thoroughly with the agent so you can be reassured your investment is safe and roadworthy.
Transport has no borders.
thanks from all above and i have noted and saved wombats links . and its now disconnected from mains . i will ring dealer tomorrow and let them know my problem. i will be just annoyed if they say i have to bring it back 150 ks and then pick it up . if they dont want to play the game i will then go through the legal lines with all my problems
dibs
gdyble
dibs
 A small price to pay to have it fixed and safe Graeme.
Ask them who is going to pay for 300klms of fuel to get it back to them, but ask nicely.
ok a little up date
its raining here on the sunshine coast (whats new)
went up to have a beer with trailer trash and drown our sorrows from the ford defeat and got to thinking about the leads . so we got a different lead and power supply from a different outlet and low and be hold no tingles so we tried the other lead again and no tingles .our conclusion because the legs and jockey wheel are down it must be earthing through them because every things wet . i didnt try an earth lead from the van to the ground before so i cant be sure ( im not an electrician so i dont know what the multi meter was telling me and now i cant remember what it was doing) but to me it makes sense but im not a sparky so i will ring one tomorrow and get some advice from him before i ring the dealer .
dibs
gdyble
O AND ITS UNPLUGGED AGAIN its running 12 volt with a solar panell
dibs
gdyble
Graeme you want one of these AmpFibian. Go here and have a look www.ampfibian.com.au/.
I CHANGE MY OPINIONS OFTEN
BUT NOT MY WAY OF THINKING
Getting back to the original problem, get an electrician to check that the extension cord you're using is correctly wired. Do this before doing anything else.
 These aren't cheap but what price a life? They enable you to safely and legally connect a 15 amp caravan circuit to a normal 10 amp household power point.
Go for the one with the "safety switch" included. (RCD in techie talk)
I endorse what has already been said Good luck for tomorrow our prayers and thoughts will be with you. Helena.
