SmartBar Mackay Festival of Arts Floriade Darwin International Film Festival
Post Info TOPIC: problems with PV charge controller
The controller has stopped giving readings and I am unsure whether I can open the controller, ie do they have ffuse etc.  any help greatly appreciated
Hi Gitsho,
Can you provide any more information on the controllerand what problems you are seeing?
If you have a multimeter can you see any voltage on the battery or solar terminals on the controller?
Is the controller still under warranty, if so you should definatly not open it.
Cheers, Nichol
my solar controllers are Morningstar. 5yr warranty. have 3 in use. Morningstar they say are the best available.
Have you changed your battery with out disconnecting your regulator?
Jim
Regards Jim
Hi Jim, no I didn"t so that might be my problem.   thanks Rgds
