Post Info TOPIC: Leaking PopTop
Leaking PopTop
Hi everyone,
just joined and looking for Advice on the best place to have my Pop Top Resealed and is it expensive.
I am located near Melton,Victoria.
Kind Regards,
After discarding something not used for years, you will need it one week later. (Law of fatal irreversibility)
I HAVE JUST DONE FOR A MATE BOUGHT ALL THE RUBBERS FROM A CARAVAN REPAIRER ABOUT $200.00 AND COMPLETED IN A WEEKEND, QUITE EASY
Brian & Sue
VKS737 mobile 1078
Thanks for that,I will try and have ago this weekend.
The main problem is the join along the Top of the Pop Top.
We were caught in the Floods in Queensland and it has leaked ever since. I think I will have to remove all the old sealant and start again.
We want to head off again Boxing Day.
Thanks again for your Help.
whenever doing any resealing of any thing all old sealant must be removed and the surface to be resealed must be thoughly cleaned
blaze
ps the completed jpb will only be as good as the prep
Thats what I did. The previous pop top we had developed a leak. I dug out all the old sealant all the way around. Really loaded it up with new sealant, never leaked again after that. I used Sikaflex. And as blaze says, give it a good clean before  squeezing in the new sealant. Use plenty too, let it well and truly overlap the join. Doesnt matter how much you use, nobody can see up there anyway.
-- Edited by rosco on Wednesday 14th of December 2011 02:00:47 PM
Sikaflex marine and auto keeps its flexibility and holds its grip.
You can clean the surface with turps or acetone which is nail polish remover, and that's what I used.
Good luck.
Transport has no borders.
Hi everyone,
thank you for all the Help.
I started to-day,but got a bit hot,I will do one section at a time and hopefully get it finished before I go.
