check out the new remote control Jockey Wheel SmartBar Topargee products Red Earth Festival Park Booker
Post Info TOPIC: Preparing Squid.
Preparing Squid.
Hope it works this time.  For those who may not know how.
I saw on a cooking show once Sheba, the way to tenderise squid is to soak it in milk, don't know if it works but have always remembered it........
What the heck, why not !
Hi Pauline,
Many years ago (about 40) I worked at the Qld Fish Board when squid was basically bait and an old Italian fisherman said you always soak it in milk. I think the enzymes in the milk have something to do with it. Don't know if it makes a difference as that's the way I've always done it.  Never been disappointed but then poor cooking can ruin anything.
jack
N.O.M.A.D.  Normally only me and dog.
Thanks Jack good to see that some of the tips you see actually work, can't remember how long you soaked it for but..........
Now they tell me!!!!!
I did have a less than satisfactory episode with my first squid.
Reported about it on the Esperance thread in the Solo forum.
Sorry about that John.  I only found the book again the other day.
Preparing squid is actually easy to do but when cleaning the squid is some kind of hard but with the instructions you have shared will definitely help me on this. Will share some details on this procedure after I have done this part.
______________________________
Cooking Recipes for One
Both squid and octopus are nicer and more tender if soaked in milk for a while .
Certainly don't need to soak the small ones for them to be tender. Learned this method in Portugal using calamari straight off the boat - clean squid in sea water making sure to rub skin and clear membrane off, set hood aside. Chop up tentacles then mix well with a little garlic, parsley, chilli, soft breadcrumbs, salt, pepper and little olive oil. Lightly stuff mixture into hood, brush with oil and grill over charcoal.
Definitely agree with you Antigoon.  The other way to soften squid  is to mash up a kiwi fruit and stir this into the squid pieces and leave for 20 minutes.  Rinse of and dry.  Then get some cornflour, eggwhite, salt and pepper squid mix and hot oil.  Cook real hot and real quick , mmmhhh, I think I am salivating!
Never growing old, just getting dusty around the edges.
Also cut up squid and soak in egg for couple of hours ..toss in season flour and cook .... serve with lemon and homemade tartare sauce and nice salad ...
The clearest path in life is always the one behind you....
