SmartBar Camp Creative
Post Info TOPIC: Jayco Westport 2001
Jayco Westport 2001
I will be going to Kulin Bush Races 7-9 October 2011, staying at Camp Hart on filling my onboard water tanks and switching the pump  power switch on the only water I get is the red hose running from my heater the pump does not switch off. is there a air blockage,or some other reason why I am not getting any pressure from the two taps in the kitchen plus the hand pump does not produce water flow either both taps in the shower do not seem to be working.no
I had similar trouble , found my battery was too flat,actually dead,pumpwould not cut out -no water much!
Always on the Road.
might be different for you since hand pump not working.
Always on the Road.
I had the same problems with a second hand 1990 traveller it turned out that the balance pipe between the tanks was above the tanks not below them the water for the sink was in 1 tank the shower the other
Found the problem Non Return valve in heater was not closing $180 later all fixed I hope thanks
