SmartBar Camp Creative
Post Info TOPIC: WIRELESS INTERNET
Ma
WIRELESS INTERNET
Does or has anyone had problems with their wireless internet.
We got out box thingy the other day (Blue did the hook up) and now find it almost as slow as dial up used to be.
It also chucks your connection off REGULARLY.  Sometimes it is all the connections you have and sometimes just a select one or two. Like I can be in the middle of reading or posting here and whamoo connection lost.
Have checked out all the connections, made sure the aerial is in a good place, the meter says we have good coverage but......
It's driving me insane..........or should that be MORE insane..........biggrin
 Hi Ma & Blue, I use wireless all the time, my isp is through telstra and while it can be slow sometimes loading a page it generally is reasonable and rarely drops out. It appears to be signal issue; do you have any neighbours using wireless having the same problem?
Using wireless Ma, remember to change the factory default code to one of your selection........my neighbour nearly died when I told him who good it was using his broadband...he hadnt changed default.
Hope its of some use or maybe another forum member has an answer for you,
and get well soon!
ozi2
Ma, just a thought, did you use a double splitter filter, ie, one for home landline and one for modem?
-- Edited by ozi2 on Thursday 28th of July 2011 09:34:40 PM
On further reflection Ma, try turning modem off and remove from power source for 5 mins, I seem to recall when I first used w/less that I had a problem and the above reset the modem. If you have a local library then the wireless for dummies is a good book to brush up on with some good tips on security etc.
Time for beauty sleep.........night Bluesmile
The Master
Ma, I've got wireless broadband. It usually works very well but for about a fortnight now it has been chucking me off too. If it keeps doing it I will be ringing Telstra. Also I have noticed tonight it has been very slow. I checked my usage to make sure I hadn't gone to my limit and been slowed down but No I am only half way through my limit, so don't know why it is doing that tonight.
I turned it off for a while and it seems to have quickened up now.
Happy Wanderer
Don't worry, Be Happy!
Ma
Thanks Oz and Marj.  Have tried most if not all of your recommendations.
We even rang Telstra Tech Support, 3 times and 3 times they were to get back to us......go figure..........they get your money and then dump you it seems.
If you go over your download limit, the speed usually slows down , considerably.I have only a 1gig limit , soI have to watch that I don,t do any big downloads.An external aerial definately makes a difference when in fringe areas.I once got signal 220 klms north west of Booraloola!Tech help can be a battle at times. I am with Telstra, only because they are the best coverage in the bush, otherwise, they are too expensive.
There is a setting somewhere on the computer that will log you off if it is idle for any length of time...now I will try and think where it is so you can maybe change it ????
Gary
www.gdaustralia.com
Mine does it automatically, after no activity for about 15 mins.You can set it up that way thru internet connections in control pannel.
Friends I was travelling Qld with recently, are now in the outback somewhere, and they've also had trouble with their WiFi. They rang Telstra a few times and it seems they're being given a new modem. Last I heard from them, they were hoping the person in India understood to send it to the CP they were heading for in Alice Springs, and not to their home in Toowoomba or the CP they were in Mt Isa!
I said good luck with that!
ring telstra and have your problem esculated to a suppervisor, I have got a lot of freebies over the years dealing with testra, once had a $400 credit to my mobile. You need to be firm, dont get crabbie, have your question written down so you dont get side tracked and persavere
blaze
Ma
Can only try AGAIN tomorrow Blaze, lost count of the number of times we have called them.  The signal says we have 100% and everything else on the thingy is listed as good..........maybe a faulty modem ???
Hello me darlings Jacko is back.
My darling if you find the modem is Sierra Wireless then you are in trouble. Darling if you toddle or should that be doodle off and ask the darling hunky gorgeous men on Whirlpool Bigpond they will happily confirm about the troublesome Sierra Wireless modems. Darlings I had so much trouble that drove darling Jacko close to insanity. Darlings now Jacko has a Cmotech Maxon modem and Jacko has no more Bigpond connection pain.
These darling gorgeous hunky men helped darling Jacko heaps with modem, correct aerial and router http://forums.whirlpool.net.au/forum/14?g=106
-- Edited by Jacko on Sunday 31st of July 2011 06:56:14 PM
dont leave till next year what you can do this year
next year may never come
no idea what ones mine are , from telstra..
The Drewsterz my band site
Milo Online  my personal site
ohhhhh no ....
sorry Jacko ... just don't find you that endearing !!
  <<   living life  >>
The Happy Helper
Jacko - sorry,but what is with all the "darlings"?
jules
(Ben, aged 10)
G'day Ma
Wireless broadband is never ever going to give us broadband reception that satellite does .
We have to get used to that .
The Master
The more you comment on Jackos darlings, the more she seems to put in next time. Best to ignore her totally.
Happy Wanderer
The Happy Helper
I'm with Telstra Bg Pond, and just lately I have been getting kicked off at least twice in a session, I am nowhere near my usage limit - don't know what the problem is.
jules
(Ben, aged 10)
The Master
Exactly the same as me Jules, not sure whats going on.
Happy Wanderer
Vic
ozi2, can you tell me how to change the factory default code please? confuse
Thanks
Vic
Hi Ace Pop Top Campervan & A'Van A'Lite Camper Trailer.....
Khalil Gibran says "We tarry forward - not backward".
Spread the laughter
Share the cheer
Let's be happy
While we're here.
The Master
Never heard of having to change default, whats that all about ozi2.
I do check my usage every few days and nothing untoward happening there.
Happy Wanderer
Vic
         I think it basically means is that your neighbour can use your internet at your expense, also read your emails etc without you knowing it.....furious
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
The Master
Yes, I realise that Vic, have heard of that happening before, just didn't know you could change your default and how.
Happy Wanderer
I'd like to know how too please.
Darling on Bigpond if you have a Wifi device you dont have to change anything. Bigpond install dont allow you to set up a connection that is not secure. If you are using USB no need to change anything. Darling playing with your security settings without knowing what you are doing darling you could change something to make on open connection.
Darling the issue is Bigpond modems are rubbish. Darling if you buy a Maxon Cmotech modem second hand your problems will vanish. Darling Jacko now has no Bigpond pain anymore Jacko has a quality modem. Darling if you changed to Telstra and used a ZTE modem you would not have any more pain. Darling Jacko is a vet surgeon but darling Jacko also has IT degree.
sandsmere wrote:
G'day Ma
Darling wireless is faster and superior to satellite. Darling the latency of satellite internet is nothing short of painful. Darling with quality Bigpond equipment and aerial not many locations you dont get good coverage and speed. Darling if you have a Sierra Wireless device darling you are hosed and in trouble.
jonathan wrote:
ohhhhh no ....
 Darling Jonathan you need help dear. Darling obviously you have never sipped a few Chardies with darling Jacko. Darling I would help you more but darling Jacko has to be on operating station at 8:15am. Cya later darling or on the road
-- Edited by Jacko on Thursday 4th of August 2011 07:41:10 AM
Vic
Look out Jonathon, you have won a heart, I think Darling Jacko may be related to Jeaney Little........
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
I think Jacko has forgotten to take her medication - or maybe taken too much???? must be good stuff!!!
Dodge Ram 3500.
NO FIXED ADDRESS.
Dita Cobb was here first Vic.
