Post Info TOPIC: Wiring up Reverse cameras
I need some help with hooking up the power on my camera setup. I bought a monitor and 2 cameras from EBAY.
When I go to hook up the power there are 3 wires.
1 negative
1 positive
and 1 for the reverse switch.
 My question is that I want to run the cameras whilst the power is on, and not just in reverse, so can I join the power and Reverse switch wire together and connect them to 12 v power???
Arald and Desleigh
Theres more to life than work.
Keep Dreamin!!
That should be fine Arald, But I would put a normal toggle switch in the reverse Switch wire so as you can turn it off if required...
Life is too important to be taken seriously!!!
Thanks Gubby,
Will do that and see how it goes
Arald and Desleigh
Keep Dreamin!!
If you are putting a camera on the van, I have powered my camera on the van from the number plate light, when I want to use it I turn the park lights on, saved a far amount of wiring and joins at the tow hitch
blaze
I also wired mine to the 'park' lights, then I can turn it on or off as required.
Dodge Ram 3500.
NO FIXED ADDRESS.
