SmartBar Camp Creative
Post Info TOPIC: water supply
water supply
Hi folks,
we hope to be off by years end, stilll gathering info. Where do travellers usually fill up with fresh water? Do petrol stations allow it? ..  where else.
jgdg
Just spend a night in a Caravan Park and top up......There's no problem with water now...I use an empty bladder after I have emptied the  Red wine from it    4 lts Per bladder I use it for a cup of  Coffee and Tea...Goes a long way
  I always leave my camping area cleaner than I found it.
The Master
Just be very careful. You will see signs saying Not for Human Consumption or Do not Drink. There are lots of taps at the Kumbia park but none suitable for drinking. I carry a 10 litre of drinking water, I made the mistake of buying a container from Bunnings as now I have to buy the 10 litre container to tip it into my container. Might as well just buy the full container.
I do have a tank under the van which I filled before leaving home but not game to use it for drinking or cooking, it always starts off a little discoloured when I want to use it.
I understand there are service stations that will let you fill your tank with drinking water. Not sure if they charge for it though.
Happy Wanderer
Don't worry, Be Happy!
The Master
At the Moonie powered site stop which you pay 22.50 a night for there is a tap beside each power station. I did go and ask if it was ok as the couple next to me were wondering too. They said it was bore water and if you were ok with drinking bore water it really wasn't a problem, perfectly ok for all other purposes.
There may be more like that.
Happy Wanderer
One hint that I used to do when bush camping on 4WD trips was to save any left over water from the billy, kettle, jug etc after boiling for a cuppa, in a separate container. This not only saves water but the boiling removes any bugs from it.
Bore water, even if safe, can contain other impurities that can sometimes "turn a tender tummy". Also makes a terrible cuppa especially if like me you have your tea without milk and sugar.
Another thing.... don't use non-potable water to clean your teeth.
Merda tauris scientia vincit
 Digressing somewhat but 22.50 at Moonie for what appears from the roadside to be a rather ordinary park is not exactly a bargain when compared to 28.00 at the 4 star rated Top Tourist at Goondi, 100ks south.
I always carry a generous supply of bottled water. Very finicky about my cuppa. Otherwise the water in MH will be OK for washing up etc.
ChiChi
The Master
Absolutely Jimricho, not something I would want to do too often but had no choice that day. Probably should have parked across the road on the other corner for free but was needing power that night.
Happy Wanderer
 I usually empty about 4 ltrs out of my bladder after a night on red wine
peedys potty toilet animated gif
-- Edited by goinsoon on Tuesday 7th of June 2011 07:23:42 PM
Goinsoon
Well put Goin soon.....  But  the bladders are great
 They make a good pillo for the beach as well, just have to blow them up to suit
guy stick head out of sand castle at beach animated gif
Goinsoon
goinsoon do you recycle the 4 ltrs
-- Edited by dogbox on Tuesday 7th of June 2011 07:50:07 PM
 only on the vegie patch
good old boy drinking beer animated gif
Goinsoon
Those cask bladders are also good ice packs if you have a large deep freeze. Partially fill them, not too tight, freeze for the esky when camping. If the bladder was clean when you fill it, you will have fresh water when it thaws.
Keeping 1 esky for frozen plastic bottles or bladders will stay frozen for up to 4 days as long as you only open it once a day to change the ice blocks in the tucker box.
I carry 25 litres of Adelaide water in the car when I'm on the job. I also bottle filtered water for drinking. I filter it at home in a Brita jug. I can drink Adelaide water, but I'd rather not. I don't have access to rain water so the filter is the best option.
I developed a bad case of giardia by drinking bore water in the Kimberley straight from the bore. I think it was the pipes and tank rather than the water, but after that I chilled all my drinking water.
A visit to the hospital and a dose of antibiotics fixed me after suffering terrible pain and stuff. (no details)
Transport has no borders.
There are always those Water Purifying Pills you can buy from Camping Stores.  Will be taking a Water Purifier with me, but might take a pack of those just in case.
Another good place is information centres they almost always have drinkable water there Helena.
If we need water I simply ask at the servo if it's ok to fill acouple of 20 litre bottles BEFORE we start to fuel up. We have never been knocked back. My theory is that they are quite happy to give a little water to sell some petrol. We have not tried this across the Nullabor but have in most other areas.
They wont give water away across the Nulabor, easy to spend a night in one of the parking area behind the road house and you get it for free, or buy by the bottle
blaze
Have a drink or a feed at a pub and there is never a problem to get 20 litres of water . Pubs have to have good water .
I have a filter jug that is narrow and fits nicely in the door of the fridge. You can get a water cask (10L) at Woolworths supermarkets - was only about $4-$5 and it lasts for a while if only used for cuppas.
Esmeralda
It aint over until the fat lady sings, and I dont feel like singing just yet!
The Master
Just be careful of the tops when buying water. I bought a 10 litre up north, could not get it open. The neighbouring caravanner had to cut it open for me, then I transferred it to my Bunnings container as it wouldn't hold the water safely after that.
Happy Wanderer
Thanks for all the info, love the wine bladder idea, the simplest ideas are often the best. We are looking forward to learning a lot more from this site.
We are going to be travelling with three dogs so the pet info in really valuable too.
jgdg
We have a + shaped thingy which you buy at Bunnings. On each end it has a different tap fitting. Can be used where councils have removed tap handles to prevent vandalism. Another good place to get water is often boat ramps, or fish cleaning tables.
