Post Info TOPIC: Typing Trouble With Post and PM Replies ?
Vic
Is anyone having trouble typing their post or pm replies please.  Mine keep superimposing on the next line and sometimes even when the words can be seen when I post it some of the words have gone missing.   One pm reply I did completely went into cyberspace and only the original pm I was answering was received by the sender?  furious
This has only started recently after I changed to a new provider and I haven't had this trouble before.....any clues please confuse
Vic
Hi Ace Pop Top Campervan & A'Van A'Lite Camper Trailer.....
Khalil Gibran says "We tarry forward - not backward".
Spread the laughter
Share the cheer
Let's be happy
While we're here.
sorry don't have any clues on that one Vic don't seem to have any problems my end
Chris & Joan  toyta prado & traveller Belair
home town Gawler s.a
"Living the Dream"
Vic
confuseThanks Chris and Joan........it's got me stymied.......confuse
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
Mine seems fine so far as well Vic, hope you get it sorted, must be frustrating.
Ma
Had that trouble a while back Vic.  I signed out of everywhere, emptied the trash bucket, did a full system scan and a defrag and then shut the PC down for about an hour.
Came back on and signed in and all was OK.
Good luck with it.  My solution might not work for you but at the time it was all I could think of doing and lucky for me it worked.
Vic
Thanks FF and Ma. Worth at try Ma. Its only when I try to type a second line, i've tried letting it run to the end and change lines itself and also changing lines myself and that is when it is superimposing......sheesh, just changed lines on this post and it working ok again......See how long it lasts  confuse
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
Ma
That's exactly what it was doing to me Vic and I tried what you did too in the beginning.
The Happy Helper
A while ago I had the same problem - did the defrag thing etc., ended taking it tech - needed new hard drive - fixed the problem.
jules
(Ben, aged 10)
Vic
Thanks Ma...see how it goes!
Cripes Jules I hope I'm not up for a new hard drive! Funny thing is it is only happening on GN posts/pms, not elsewhere.
I was also having trouble with backspacing to correct mistakes........Hmmmm.......did the degfrag bit and so far this seems to be working ok so maybe this has fixed the problem? Thanks for the help everyone (fingers crossed). biggrin
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
