Post Info TOPIC: Fibre glassing
Fibre glassing
Whilst in Mildura recently..I found a nasty leak under my awning and coming inside Had to get the tarp out it was that bad.After close inspection will have too do some paint stripping and cleaning in and around gap....Any suggestions on something to plug hole and then Fibregallss it
  I always leave my camping area cleaner than I found it.
What is the "hole" made from?
If you're going to fibreglass it that will seal it, all you need is something to stop the fibreglass until it sets, even just a bit of flywire rolled up and pushed into the hole.
Life is too important to be taken seriously!!!
Peter n Margaret Gubby...Rusted away I figured....Guess I'll put some bog in it smooth it out anf then Figregalss it...I'm only talking about a 5 cm I have only just started to clean around the area
Try to make sure that you either cut out all the rust or treat it otherwise in the not too distant future you'll be doing it again...
