Post Info TOPIC: Jayco Heritage water tanks.
Hello All,
We have a 2002 21'6" Heritage. I have just filled the front tank and thought that it would be connected to the rear and fill that at the same time. Not so. My questions are,
What is the capacity of these tanks and is there some valve or tap that will allow both tanks to be used at the same time? There are two fillers, one near the front and the other further back.
Regards to all
Phil.
"Some days you are the Dog and some days you are the tree."
Harry Brown.
maybe should ask jaycoconfuse
Gidday,
We have a 23' Sterling with 2 tanks and we have a tap mounted on the chassis under the van between the tanks. Closed the front tank only is used, open the pump draws from both tanks.
Ross
http://rossjdaniel.blogspot.com/
Master (of Mischief)
We have a Future System with two tanks and two filler holes and two taps in the kitchen sink, we keep one tank for drinking water and the other for showers. Each tank needs to be filled, one at a time
The average capacity is 60 litres per tank.
I have 2 fillers but the tanks are connected so I can use water from both tanks. The 2 fillers just makes it quicker to fill each tank. Using the small connecting tube would be very slow.
I don't use the tanks much as I'm connected to mains when I'm parked up.
Transport has no borders.
Thanks to all who replied, I will have to check that the valve is open.
Phil.
Harry Brown.
