Post Info TOPIC: Myrtle has storage space outside on her head
The Master
Had no idea till today there is storage space on the outside on top of the cabin.
Have two campervanner friends staying in the park over the road for a couple of nights, Jazzin Around and a friend of hers named Clive. They both like the look of Myrtle, can't believe what great condition she is in. Lorraine pointed out somethig I had no idea about. There is quite a dip above the cabin area for storage. (above my head when driving) When she had a van the same some years back she had a waterproof zipped bag that went up there and stored things to give more room in the van. There are bits up there to clip ties into.
Now where will I find a suitable bag?? Any ideas.  Also realised the reason there is no mozzie netting on the front zipped part of the pop top is to get stuff off that storage with ease. Will post a photo showing that part of Myrtle so you can understand what I am gabbling on about. In front of the pop top, that area has quite a dip, not sure what its called.
Happy Wanderer
Don't worry, Be Happy!
Hi Marj.  [ You have no idea how much I look forward to these up-dates.]
I don't have that on mine. I think my Pop-up bit is longer.
I'd have a look in Camping stores, and also keep an eye out in Op-shops for something that might be suitable.   About what size is the area?
Do you think one of those solid Luggage cases that sit on the roofs of SUV's would be too big ?
Here's one link.  There are others you can Google.
http://www.nextag.com/car-luggage-carrier/stores-html
-- Edited by Sheba on Saturday 9th of April 2011 09:21:54 PM
There are a few versions of solid roof top storage of varying sizes. Some camping stores and places like Repco, Super Cheap Auto, Auto Pro etc may have something for that space up on the roof.
There are small roof racks to fit up there as well.
Truck and van fitters may have something as well.
I thought you meant the space above your head in the cab until I read further and saw the pic.
You're really having fun setting Myrtle up, aren't you. It's an adventure all by itself. Have fun, it's yours.
Transport has no borders.
The Master
Its raining and dark at the moment so not going out to measure it but I will. Would be a good metre each way I think.
You know what I also found out from Clive. I'm supposed to be putting an additive in the fuel as origianlly made for leaded petrol. I found some in one of the storage spaces from previous owner so will do that next payday. I've only put $40.00 in so far since getting her so not a problem but will fill up on Wednesday.
So glad you both look forward to my updates. Its great to hear feedback each time I write on here. Gives me confidence to get going.
Happy Wanderer
The Master
Sheba My poptop goes to above the driving seats, no further forward than that.
CG, Thanks for that, will do the rounds of shops next week. Sounds like quite a few options available.
Happy Wanderer
You probably have to do that additive each tank full.
I run my tanks down to about quarter and when I fill up I add injector cleaner to the diesel.
You don't need injector cleaner, but the principle is the same. It keeps things clean in the engine where the lead used to be.
That's girlie mechanic speak for you better put the stuff in to look after your engine.
You've got a good unit by the look of it. Look after Myrtle and she'll give you a lot of happy miles/kilometres.
The Master
Thanks CG. Clive said to put 10 mil to every 10 litres of fuel, so that works out easy.
Great when you explain it all in girlie speak and not all technical. So much easier to understand.
Happy Wanderer
Hi Marj,
I read all of your updates with interest and I think it's great that you are getting so much enjoyment from Myrtle before you even set off on your travels.
I think you ought to have a look in the junk shops/$2 type shops for the zip bag. I have bought a few different sized plastic zip/storage bags for my van quite cheaply in those shops up here. Hope this helps.
Cheers. Pam. smile
 Cheers. Pam.
Safe and happy travels everyone.
The Master
Thanks Pam, will be a cheaper option, so will look there first. Just have to make sure they are waterproof. Seems there are lots of options I hadn't thought of.
Happy Wanderer
Did you check out the link I gave you in my first reply Marj ?  I've been checking out more sites, but there are a few on that Link that are waterproof, and around the $30-$40 mark, which is a lot cheaper than the Solid ones.
The third one down, you can get from Amazon.
There are also some on e-bay, if you go there.
You might even look in Target, and K-mart, and Big W.  They all have Vehicle and Camping sections.
-- Edited by Sheba on Saturday 9th of April 2011 10:22:23 PM
Vic
Hi HW,
I had a Mazda E2000 Campervan with the same space above the cab (it was a Dove camper conversion), I bought a 2 man tent which I stored up there in a blue polytarp, tied down with ocky straps, this was my "emergency" accomodation for a caravan park or similar in case I had to put the van in to get something fixed while I was travelling. Never had to use it as such but it was comforting knowing it was there if I needed it, cheaper than staying in a hotel/motel room somewhere if it had to be in a workshop overnight.....
Vic
Hi Ace Pop Top Campervan & A'Van A'Lite Camper Trailer.....
Khalil Gibran says "We tarry forward - not backward".
Spread the laughter
Share the cheer
Let's be happy
While we're here.
Hi Marj, it's all looking great.... not long to go and you will be ready!
Master (of Mischief)
Myrtle looks great HW, the ariel sticking out the roof looks a bit large, is that the one you use at home or only when you travel.biggrinbiggrin
The Master
Wombat, never noticed that until you said. had to go back to see what you were talking about. No that aerial is only for when I park in bunnings carpark. Its a special one.
Thats a good idea Vic, and can store my en suite tent up there too.
Yes Sheba, did check it out briefly last night but was feeling unwell. Will do it properly today.
We went for lunch at an unnamed Pizza place in town yesterday. Spent the rest of the afternoon with my head in the toilet bowl and other than when on here curled up in my comfy chair. Have only just eaten again and only a couple of sao crackers.
Happy Wanderer
Yep, thought it was special, it even has it's own lights. lol
Sorry to hear you have not been well after your pizza, with your head in the toilet bowl, doesnt that make a mess on the floor? lol
The Master
Now, now wombat, you know what I mean.
Happy Wanderer
We have just bought a new rooftop bag from Aldi. About 90cm X 45cm. It appears to be very strong and would probably go well in that space. We originally bought one from Supercheap but after many hours of sun exposure it collapsed last trip. Supercheap no longer carry them. Happy hunting. Isn't it great when you've been searching for something for a particular job, you walk into yet another shop and 'bingo', there it is.!!!
smilesmilesmilesmile
Robyn & Ted  Livin' Dream
http://pricey43.blogspot.com
The Master
Thanks pricey, will check out our Aldi here tomorrow.
Happy Wanderer
Make sure the plastic has a bit of UV resistance. Most plastics disintegrate very quickly when exposed to the elements.
You may have to fit a couple of cheap, light roof racks on which to mount your storage. I wouldn't put it straight on top of the roof.
Have fun shopping for that stuff now. This is fun! I'm having fun watching your set up progress.
Now I have to get roof racks strong enough to hold my 25kg roof sign, frame and lights. I've found a set at Super Cheap Auto for about $230. More drain on the diesel fund, but I call it an investment. I hope the tax man sees it that way.
The Happy Helper
Myrtle is going to be the "bees Knees" when she is on the road, if you are looking for something up there and have to put light roof racks on anyway, what about a lightweight aluminium tool box - usually have latch locks, will be waterproof, and can be securely attached to prevent theft - just a thought.
Can't wait to see the next instalment - "The Adventures of Purple Myrtle"- can't wait to see her up here.
jules
(Ben, aged 10)
The Happy Helper
Another thought, sorry I have a mind that races through thoughts all day, if you think that aluminium is too shiny - you can always paint it - yep PURPLE!!!!
jules
(Ben, aged 10)
 laughing.gif I can just see it!
I'm assuming this storage dippy bit has drainage? It looks a bit like a dam. confuse
I have the same space on top of my van and have been trying to think of how to tie down stuff up there safely,
carried my small Jerrycan up there on the way back from Kununurra, but I hate Occy straps... so will sus out
all ideas on here and see if I can come up with something as well..
Vic
Fair go Wombat......everyone knows that is a UFO detector.......wink no
Vic
Spread the laughter
Share the cheer
Let's be happy
While we're here.
Geez I wish I had storage space in my head!! biggrin
winkIt seems to be full of so much stuff I cant remember anything more!!
Cheers,  Gerty. ... at home
Vic, yep, I forgot HW would need one of these up her way. lol
Hi HW
I too love reading about the getting and setting up of Myrtle.  The space to put things is the hardest thing to sort out in compact "homes".
Esmeralda (yes my petite van has been named Esmeralda) has very small cupboards and only one real size drawer but she is slowly getting sorted.  I took her down to Melbourne to get auto steadies fitted on Saturday - but apparently she is too old to have the right legs so is now getting modern legs installed with the auto steadies.  I keep her at my parents' home in Thornton (near Eildon) so every time anything much needs to be done I have to take her down the Black Spur - in fact the first time I towed her was up and over the Spur, a narrow and winding road.
Auto steadies will be great - just push a button to put them down and another to put them up. Really only battery, charger and wiring to go!!
Cheers, Es
Esmeralda
It aint over until the fat lady sings, and I dont feel like singing just yet!
The Master
Haha!! You guys are hilarious. Now where do I start. Have spent part of today helping Jazzin Around with her computer before she moves on to the Deni Rally.
Have a list of bits to get tomorrow, suggestions from Jazz and friend. I must find some potable hose with an attachment to fill my water tank as will be easier than using a watering can.
I'm presuming Bunnings will have some.
Also will do the rounds looking for a container for the roof well. I'm presuming it has drainage as there is no water sitting in it.
Also need to find a long lead with hooks both end to tie Punky to the van when camping probably from Petstock.
Happy Wanderer
I would think Bunnings has a "Drinking Water" hose.  I got mine at another Hardware Store.  Won't be hard to find one.
Hello HW. Just a thought on you getting a long lead for your little doggie. whenever i see dogs tied to the van, they always end up wrapped around wheels, or anything else they can wander around or through. what i do with my little fella, is i have a Large screwdriver that i push into the ground, with a lead long enough to let him reach the shade, or the sunshine, whichever he prefers. Just drop the lead over the screwdriver, and he can wander around and around with no tangles !!! just an idea you may want to think about !!!!!!
By the way I also follow your adventures of setting up purple myrtle. you should be proud of your acheivements, won't be long now, and we will be reading about your travels,  dazren
IF IT IS TO BE !! IT IS UP TO ME !!!
