SmartBar SmartBar
Post Info TOPIC: time frame for water in tanks
confuseCould someone please advise me on the duration of keeping water fresh in tanks.
Currently travelling so only using filtered water over sink, otherwise hooked up to caravan park water. Water has been there five months to date. Is it advisable to drain and only fill when going "free camping"?
That is what I do, when van is not in use i empty the what tank , when on the road when you have good tasting water drain the tank and refill
Stored rainwater in tanks may be there 12 months without a freshen up, I dont bother hooking the van upto the mains at a CP, I just keep filling the water tanks and not quite so sparing with it
blaze
Water does not "go off".
Bugs can grow in it though and we add 4ml of swimming pool chlorine per 100 litres to our tanks every couple of weeks or whenever we top them up while on the road or before starting on a trip. That kills them all.
We then filter our drinking water wit a 0.5um active carbon filter as we use it. That takes most things out, including the chlorine.
It does contain dihydrogen monoxide however!
Merda tauris scientia vincit
The Master
I will be emptying my tank and rinsing it. Don't know whats in there so best to be safe and sure.
Happy Wanderer
Don't worry, Be Happy!
We rinse ours before taking off, fill it and put in some bicarb soda, does the job nicely. Too many bugs grow in water that sits for too long.
The Master
Thanks for that tip Firefly, will be using Bicarb too.
Happy Wanderer
Thanks everyone for your tips. New to this adventure and with all the water restrictions etc, just dont want to waste anyaww
Rainwater storage tanks may be 12 months without a cool, does not bother me hitch up the van of the network in a PC, just keep filling the water tanks and not so short on it. We also filter our drinking water with activated carbon filter 0.5um as we use it. That takes most things, including chlorine.
Rainwater tanks
