Post Info TOPIC: NSW. and VIC . Road Condition Links.
Found these links as well.
www.rta.nsw.gov.au
www.vicroads.vic.gov.au
Click on the first site with  this one.
Don't know how this is going to turn out.  The typing is starting on the right-hand side of the page, and I don't know why, and I can't fix it.
-- Edited by Sheba on Tuesday 7th of December 2010 09:36:34 PM
The Master
I got into it ok Sheba.
My neighbour who has been in Melb the last two days caught the train home via Bendigo (to Echuca) tonight. They were told when they got on the train that it would only be going to Bendigo and buses would be used from Bendigo to Echuca. They weren't told why and changed to buses at Bendigo with no explanation.
My thinking is flooding over train tracks somewhere between the two towns.
Happy Wanderer
Don't worry, Be Happy!
Thanks for the links Sheba,
Not sure why the links are going over to the right though,
Vic
VDU
(Formerly VHW but re-registered due to pc problems)
We are leaving Qld Xmas day and arriving rochester caravan park 28th, any reports re conditions in the area
Goinsoon
The Master
goinsoon, Rochester Caravan park went through a massive flood only a couple of weeks ago. The whole park under water.
Not sure how it is now as they would have started to clean it up when this current storm started couple of days ago. Supposed to get a months rain in 2 days.
We had torrential rain and thunderstorms today with Echuca streets flooded.
Someone did say the rivers are now higher than they were in the last floods, all paddlesteamers stopped from operating, will be interesting if Rochester CP was affected. If I hear any more will put it in this thread.
Happy Wanderer
Thank you Happywanderer, I will be gutted if I cant get down there, I am going to the Caravan rally in Elmore and while there want to see my brother in Tatura, he is in his 80s so mit might be the last chance as he is not in the best of health
Goinsoon
Hi Sheba,
If you're using the advanced editor you will see at the top next to and just right of where you click on B  I U there are four icons with little horizontal lines....the first one is "left alignment", the second one is "centre alignment", the third one is "right alignment", and lucky last is "justify" (text spacing adjusts to give aligned margins both left and right).
Click on the first one to reset to left alignment.
cheers,
Jim
PS: Thanks for the links which I have bookmarked.
Merda tauris scientia vincit
The Master
I will check for any more news on Rochy CP in tomorrows paper goinsoon and let you know on here.
The sun is shining today so as long as it keeps like that will dry out in time. I will try and go for a drive on the weekend and take some photos of the CP, its about 28ks so not far. As long as the weather stays fine as a lot of the roads have been closed.
Happy Wanderer
jimricho wrote:
Hi Sheba,
cheers,
Jim
Thanks for that Jim.  It worked, but now I'm not allowed to edit it.
I'll remember for next time.  I don't remember clicking on that area the first time though.
Cindy may be able to shed more light on this but I think there's a time limit to being able to go back and edit a previous post.
