Post Info TOPIC: tv antenna's with a pop top van
hi, if and when i get my pop top campervan,
whats the easiest way to add a tv areal to it?
I saw one guy that had his permantly on the back of the van
i know of the wingard ones like my dad has in his van but i dont know
how well that will go with  a campervan,
I thought of satelite but there pretty expensive i think?
 and take up alot of room on the roof?
what else is out there?
The Drewsterz my band site
Milo Online  my personal site
Hi Milo
My van has one that clips into a clamp thing on the side of the van and stands up about 3 foot above the roof. I have seen ones that people clamp to the drawbar and they use a pool cleaner pole to raise the aerial way up high.
Allara
PS glad to see your avatar back
Enjoy life above ground...you will spend a lot of time under it
Allara wrote:
Hi Milo
Allara
Mine is the same as Allaras' Milo.  Haven't used it yet though.
Watched a T.V. show earlier today about some kids trying to live off the land. One young male said something interesting.
"Watching a fire of a night when alone in the bush is like watching T.V. when i am at home".
Good dont you think?
CCB, He must watch a lot of soapies when at home. .If I had to watch them I would think the same. .No the fire is more interesting... And there is more going on in the fire..Bob n Bev
Ma
and you can make a lot more sense out of a fire than off the idiot box.  We haven't turned ours on for nearly 2 months now and don't miss it one little bit.
Wow Ma, 2 months without it.
I don't remember when I last turned it on...no
Sorry, couldn't help myself
Kalangadoo with a wheel barrow & water bag
Ma
You are forgiven Grumps.   There are much better things to turn on than the telly that's for sure..............laughing.gif
Sheba wrote:
Allara wrote:
Hi Milo
Allara
That's the one I got from Dick Smiths  designed for vanners fits into the poptop lock down clamps works fine. I also can mount mine into a pool cleaner pole for extra height if required  so simple to install and get up and running
The Master
Thanks for that info wombat, knowing we can get it from Dick Smiths will be a help when I go looking.
Happy Wanderer
Don't worry, Be Happy!
Thanks from me also.
Was uncertain about this but not now.
Dick Smith's...easy...  smile
 Cheers. Pam.
Safe and happy travels everyone.
Mines similar to Allara's also, but I've got a plastic clip screwed to the pop top. The antenna pole clips into to hold the pole steady.
Ross
Hello Milo...
I've had four different TV aerials on my pop-top van.  Two were useless, one was pathetic and the latest (one week old) looks like a winner.  Two were plastic rod contrivances shaped like the letter T - over a hundred dollars each and they were the useless ones.  The third was shaped like a dinner plate and cost about $70 at Bunnings.  It was called "Antsig" or something similar.  It was the pathetic one.
Last week in Carnarvon WA I bought one that looks like being a beauty.  It's called an "Aussie-Sat"  and it rotates to get a good picture by means of a remote control that you operate from inside the van while you are sitting watching the picture.  Pretty pricy at over $200 but I'm hoping....ashamed.gif
... Big Al...they seek him here ... they seek him there ...
I use an "Explorer" antenna shown below.  It's bolted to a length of anodised aluminium tube and clipped to the side of the van with a couple of tube holders, both available at marine warehouses.  The mounting on the tube is such that it can be easily changed for vertically polarised signals.
The antenna is supplied complete with built in booster, cable with "screw on" connectors (F type), and a "through the wall" feed through and power injector (to power the booster), plus a 240v plug-pak and 12v dc cord for the power injector.
Merda tauris scientia vincit
We have a "Happy Wanderer' which is like Big Al describes above. Plastic tube in a T shape which can be swivelled vertical. Ours is fantastic.
 We have the accompanying book which tells us how to set it in nearly every town in Australia.
We have a booster attached as well.
 Most of the time we pick up more channels than others in the immediate area. These can be purchased at most caravan or camping shops.
smilesmilesmilesmilesmile
Robyn & Ted  Livin' Dream
http://pricey43.blogspot.com
You Rang....... Ma..............
Waits n silence in the norti corner for Ma to turn something on...............wink
Hoo Roo Happy Days
Grumps
Leave only footprints - Take only photographs
LEAVE THE PLACE IN A BETTER CONDITION THAN YOU FOUND IT !!!
Ma
Oops........mustn't have had my glasses on at the time of that post Grumps.
Lets just say that "it has been turned on"  whether that be telly or otherwise is up to your personal interpretation.........LOL
