Post Info TOPIC: Hot Water
Hot Water
Thinking about putting in hot water for use at the sink instead of  boiling the jug every time, any ideas which way to go?
In Perth at the moment.
We have a small Reva electric ho****er which sits in the cupboard under the sink. It is instantanious and is great for washing dishes , hands, etc. Only thing I would suggest is to not get too smaller flow rate otherwise to get enough heat in the water you have to run the water very slowly.
hope this helps!!
smilesmilesmilesmilesmile
Robyn & Ted  Livin' Dream
http://pricey43.blogspot.com
G'day Colsa, There are usually a couple of ads for small hws in the c and m mag. or caravan world.
wr smith
If you want gas and electric the Trauma 14L stainless steel is an excellent economical on gas hot water heater.  The Trauma comes in gas only or gas and 240V electric.
Have a look at this one. It is 240v so one would have to be in a caravan park.
http://www.rvpoint.com.au/portal/tabID__204868/ArticleID__3047715/DesktopDefault.aspx
Or
http://www.caravansplus.com.au/catalog/product_info.php?products_id=7645
Then you have the gas/240v ones Truman and Suburban who both have a storage capacity of around 20ltrs.
http://www.caravansplus.com.au/catalog/product_info.php?products_id=3766&osCsid=6b0dd3bd21dc4d0f22f1510c6ae501a6
http://www.caravansplus.com.au/catalog/product_info.php?products_id=8521&osCsid=6b0dd3bd21dc4d0f22f1510c6ae501a6
Have a look and decide yourself.
We have the Suburban in our van which we have had for 10 years without a single problem.
Cheers Dodg.
I believe there's a unit out there which fits to the tap and gives "instant" hot water.
Looks like a lot of shopping for you. Have fun.
Transport has no borders.
The brand name is actually Truma.
Maybe not quite what your thinking about but we have a Coleman water heater. Probably a bit big to sit inside the van, we use it in the annexe. Great for showers, but also hot enough for a coffee. Runs on small gas cylinders so not too much to store, or for greater use, can be hooked up to the regular bottle.
I have a Truma in my MH too .. It was part of the overall setup and at that time I knew nothing much about them at all ..
It works on both Gas or 240v and has really been performing well on both counts ..
so .. I couldn't be happier !
.. would suggest you look into them .. to see if they would suit your 'style' and your budget ..
Jon
(currently in Albany, WA)
  <<   living life  >>
Thanks for all the info guys, it was a help.
