Post Info TOPIC: using a generator??
using a generator??
Can someone please tell me if we can use a generator in National Parks?? We are looking at the silent ones as opposed to noisy ones.
Thank you
Caron
__________________________________________
"Life is like an unwritten book, you decide how many pages are in it"
Hi Caron.I bet you have opened a can of worms up.Be very interesting to read the different replies.Cheers.Ibbo.
"Wings Over The Navy"
Hi you can run the silent generator there are two types one solar the other wind types
Hi Caron some you can some you cant. Daryl
D.L.Bishop
all i know is that when a generator is on its noisy , when its off its quiet...lol....biggrin
-- Edited by milo on Saturday 6th of February 2010 10:38:48 PM
milo's site
no in Victoria
new policy no more warnings
infringement notice straight away.
no grounds for exemtions
same with dogs
it's a no go in every national park that I have been in, heavy fines if caught as well
so where can I use one??
We want to free camp and intend on buying a Honda silent generator.
Caron
most free camps allow it but please use discretion as other campers get a bit grumpy, normally between say 10 in the morning until 3 or 4 in the arvo is acceptable
we pack up and go when confronted by noisy gennys but I have seen a couple of brawls over the use and times of them
have you got the camps Australia book, it outlines most free or low cost campsites
is there a difference between a noisy one and the silent ones made by Honda??? I am confused.
If I buy a silent one then I expect it not to annoy anyone else!!
Caron
Caron no engine powered generators are silent
on long service leave saw 3 fights and police called twice over generators. generator users have no consideration for others peace and quiet. generators are the scurge of free camping. buy solar panels and have peace for yourself and others
Caron
In the still of the night out in the bush sound carries a long way and at times you if you are deep in the bush you can hear a pin drop (so to speak).
Many go bush camping not because it is "free", which is a bonus when it is, but to enjoy the sights, smells, and natures sounds in the quietness of the bush.
As Martin said there are no silent generators; some are less noisy than others.
Ron & Shirley
www.ronshirl.net
Hi Caron I use a Kipor geny a copy of a Honda, I use it for heating or cooling ( fan heater orAircond) If the weather is at these extremes I tend to camp where no body else is, also found road works gravel dumps extremely good usualy you are on your own & they are generaly cleaner than road side stops, some i wouldnt let my dog out. Not dog faeces but human!!!! Daryl
-- Edited by DeBe on Sunday 7th of February 2010 03:00:59 PM
-- Edited by DeBe on Sunday 7th of February 2010 05:13:16 PM
D.L.Bishop
Caron look at why you think you need a generator and look at is there an alternate if there is, is it cost affordable if not buy a generator and learn to fight a bit blunt but thats the case
Not wanting to start something here. What if you have to use a CPAP machines at night.What do you do then.A life may depend on it.
I CHANGE MY OPINIONS OFTEN
BUT NOT MY WAY OF THINKING
I've seen a CPAP machine used with a 12v battery/inverter combination. Would need to make sure battery properly charged and would suggest a good quality pure sine wave inverter (to be on the safe side). I don't think CPAP machines draw a lot of current so the inverter need not be a very large one.  Check with the machine supplier first.
Merda tauris scientia vincit
my B.I.L. and S.I.L. both need the positive ventilation machines (cpap) and they found two that ran on "d" cell batteries, they last nearly a week giving 10 hours per night
if not then a "drink can" type 100 watt inverter would easily do it, dont need pure sine wave as it is simply a small air pump, same as fish pond pump and is not susceptible to current impuritys
The law said I'm not to use a generator in national park but is it ok to start my car up to charge the caravan batteries & have it running for 2 hours. Do they fine you if you use your car to charge the batteries???????????
I drive the only Prado in Australia with a talking tacho !!!!!!!
You know when your landing gear is up & locked, when it takes full power just to taxi to the terminal.........
An El Cheapo or "modified sine wave" (a misnomer if ever there was one) would probably be ok with some or maybe even all CPAP machines but if the use of the machine were as critical as the original question implied I'd at least check this out with the supplier or manufacturer and go by their recommendation.
my rellies have had three of different kinds and they were all fine on standard inverters, they then found the battery powered ones and have been happy since, the first ones were run from the small inverter for 5 years
this was discussed a few pages back, all was revealed in there as well!
Well Biggles I recon a lot of diesel vevicles Ive heard start up & left idling for ages early morning make more noise & smell than my Generator
D.L.Bishop
the problem with running your engine to recharge a battery is that you would have to idle at a minimum of 1500 rpm, any less than that and you will be pulling charge out instead of placing charge in, the time factor for a flattish 120 amp battery would run into probably 4 - 6 hours, not something that I would recommend doing
grab another battery and a small solar panel and a 100 watt inverter and everybody will be happy
just as an afterthought on cpap machines and the operation away from power
this website will be very helpful for those needing this machine and still wish to free camp
http://www.cpapaustralia.com.au/shopping/12-volt-battery-cpap.htm
There are some National Parks where you can use a genset in Nt and WA, and there may be some in other states. In 2007 they were allowed in Gregory and Keep River NP's in NT. In the Bungles there are separate generator areas. Likewise at Cape Range NP near Exmouth. Thomas River/Cape Arid NP allowed them in Nat Park section. I am not saying these are the only ones - just those I know of.
wendyv
Thank you
caron there is no such thing as a silent petrol motor , even though people do call them silent . They are well noise insulated  by the design of the housing and running on eco mode are quite but run them full bore and you know they are there .
Mick themungrel and Sar mini foxy Jack X
Gennys are out .for camping in NPs........try staying in one if you got a chainsaw.....big trouble.......I still say Solar panels are the way to go...
