Post Info TOPIC: Under Van Damage
Under Van Damage
Myself and She Who Must Be Obeyed, (SWMBO) at 67 and 63 repectively plan on doing a 5 year lap of Australia starting in Jan 2010. Just wondering what tips anyone can give regarding what to look for (Damage etc) when, checking the underside of caravans for damage etc. Never had a caravan before so, as Shultz, used to say, "I know nothing." Many thanks
Hello Noel.As a new guy yet to go on the block I have found that apart from mechanical probs under the van(if any)one of the most likely things to crop up is damage to water fittings,tanks etc.I have fitted guards to two of the fittings on my Penguin just in case.Noel I amcertain that the more savvy members will be going out of their way to guide you.Oh and a hearty welcome to the Forum.Cheers.Ibbo.
"Wings Over The Navy"
well yet another wombat, oh well a big welcome to you
first up make sure it is not one that has come down from the floods, CHECK CAREFULLY IT"S PROVINANCE, if it has been through the water it's life is very short, dont buy it
as Martin has stated, check all water inlets and tank for stone damage, have a quick look at the axle (is it straight, are the tyres wearing evenly (no scrubbing), is there major stone damage underneath, check the position where the body meets the floor is there water or grit penetration trying to seperate the layers, if so how bad
grab a wheel and with the brake off and van on the ground, just see if you can move the wheel backwards and forwards (spring hanger wear) also check wheel bearing movement , put the brakes on can you move the wheel at all (brakes working)
check the placement and condition of any wires including those that enter the bodywork, check spring "u" bolts for excessive tip wear from stone abrasion
check rear of light sub assembly for intrusion of water, grit or abrasion
check tow hitch for excessive wear and for fitment to the 50 mm ball (place on vehicle and try to move the hitch sideways and up and down) excessive movement replace the hitch and or ball
check condition of light to vehicle connection, do ALL lights work
as you are looking around the van you will find that it will "talk" to you, it will tell you if it has had rough treatment and how it has been serviced and generally been looked after, just listent to what it has to say
Many thanks. All points help. We are going to get the van first then the towing vehicle.......hopefully that will avoid any major stuff ups. Regards
well when you do get a vehicle and van be sure to find the weight of the van and the allowed towing capacity of the vehicle and dont exceed the tow capacity of the vehicle
also check the drawbar weight on the van and the allowable drawbar weight on the vehicle, do not exceed that either
when packing the van please try to keep it as even as possible with at least 10 % of total weight  (fully loaded) on the drawbar
less than 10% and you will get dangerous tail whip which could end in a jacknife and death
more than 10% and you will have the tail of the car dragging
but look it will be a great time searching out the vans and vehicles, take your time and find the combination that you can live with and enjoy
it probably wont be the first half a dozen vans you look at but dont feel pressured into buying any of them, the one fo you is out there somewhere
Welcome. Dave has the best guide to buying a van. Well done!
Correct towing gear also makes life safer and oh so much more comfortable. Hayman Reese do the strongest and most reliable. Then use their leveller bars to ensure weight between vehicle and van is stabilised.
When the set up is right, the travel is easy. Then all you have to do is check the towing mirrors to prepare for the idiots following you, and the rear vision mirror to make sure that alluminium box with staples is still following you.
Enjoy the countryside as it slides past, and sing along to the stereo.
Safe and happy travels. Cheers Granny
Transport has no borders.
