Post Info TOPIC: Dometic B330 Aircon Start Current
Anyone out there with a Dometic B3300 aircon mounted on a motorhome who can tell me what the power draw is  to start and run the unit.  Have been into the dometic site but no help on this topic.
Thanks
Found out, it will take a 2.6 KVA genset to start and run
Thanks for your post i have one now i know i would have to have a 3 K va to be on the safe side
3 KVA would be plenty to kick it over and run it with some other gear on as well.
Was a bit surprised I never heard back from the manufacturer.  Their 1 -800 number quoted in their website  isn't connected either.
I did find a site that pointed out another issues  that may crop up down the track .  If the fans won't turn on the aircon  the bearings  my require oiling  . Apparently they have a wick on the bearing housing that needs oiling, if left standing for any length of time they gum up and that  requires climbing onto the roof to turn the fan to free it up. It is only a temporary fix  and  will stop again if not oiled.  I would look at seeing if it could have a grease nipple or  oil reservoir fitted, Yours may not be a problem like others I know of
Try this site if you have a problem down the track
http://www.fixya.com/support/dometic
