Post Info TOPIC: Camper trailer insulation
Hello Travellers, Can anyone suggest a quality insulation to use under the mattress in our Jayco Swan. We currently have some blue foam type insulation that is adequate,but are always open to suggestions,especially when comfort is involved. Cheers NormJean
Try a sheet of "Coreflute" ie the plastic used for Election banners and Real Estate signs - try running flutes one way say; Front to back then layer a sheet the opposite way side to side. That stuff can insulate igloos.
KJB
Polystyrene sheet (25 mm.)
KB
Thanks guys, all fixed now.
NormJean
NormJean,
We added a light blanket under the mattress in our Eagle. Also a sheet of eggshell foam on top to give us more comfort.
