Post Info TOPIC: Exterior door bowl protector -https://www.ebay.com.au/i/301995759274?chn=ps
Has any one used this type of protection please? If so brand/seller and durability etc. I have one door handle area that seems very thin on paint and appears scratched easily. I don't want to use the clear vinyl type. cheers and thanks Craig
Cheers Craig
I had four of those type of protectors on my car,took them off after getting a finger nail caught between the protector and the door skin,yes it b...dy hurt.
Some politicians and babies nappies should be changed often for the same reason.Oh crap,did I write that?
Thanks Pete ( 750mm ?) Just what i was looking for, as i must be hitting the panel behind the handle to mark the paint.
Cheers Craig
I know you said you didn't want the clear vinyl tape but good quality tape is better than that junk
If you want to try some tape I have what they use on the leading edge of a Boeing wing here somewhere, send me a PM & I will gladly send you some to try, you will just need to trim it to shape.
Just remember to use a hair dryer or let it sit in the sun to go soft so you can stretch it into shape
Sent you pm Rod and had read the ebay tape instructions
Cheers Craig
