discover a comprehensive directory of free and low cost camps check out our comfortable cushions check out the new remote control Jockey Wheel Lithium Batteries Learn more about Sat Phone Sales Learn more about our special Townsvile rates Learn more about our Pet Travel Accessories Learn more about our CPAP machines designed for caravans
Post Info TOPIC: Vitro 12v 230L fridge / freezer door latch fix
This is a NEW fridge and the feed back I got from trying to fix is not very desirable . So I had a go / look at how it works or doesnt !! the hinges had been reversed before I bought as I wanted doors hinged on right . Opening on left ., Since fitting fridge  on right corners the doors would open !! Ahh ! Some thought ??? Gravity doesnt help here . A spring ?  Pulled biro pen apart cut spring in half . Fitted assembled back on door . So far seems good ., Now I have a pen with no spring !!CB37DE29-020E-492B-B65E-51EEF54C33B6.jpeg
There is no way like it was it would phase ADR the way it was . The retailer up in Queensland didnt seem to care ! Other than this catch the fridge / Freezer is working fine ! It is not a cheap fridge ! Over $2k .. 12v compressor type .
AK, you saying it didn't have a spring??? Cause mine did (118Lt model) and looks like the same catch.  The only problem I had after I swapped the door was the lug the door pivoted on the top LHS snapped off. I just drilled through the mounting plate and fitted a small M4 bolt as the pivot pin.
Steve, Di & Ziggy We named our Motorhome "Roadworx" because on the road works "Home for Summer"
Yes no spring . Looked at it for weeks and on travels . The vacuum holds doors shut to a point . But looking at the catch ? The stricker was not being captured when shut . As this way it is up to lock . Opening from other side I assume it would be upside down to this .?? Another thing is the handles are way too small to grab ! The Mrs has trouble opening . Design design !!
With the Striker, I do remember having to bend it down slightly for a better grip.  But that might be the difference in single door (mine) and a double door.
Yeah there's a few quirky things with the Vitro, but overall I'm hooked keeps everything ice cold, it's quiet and more space compared an Engel upright and doesn't put a big dent in the batteries overnight.  I will say though I removed one of the door shelves so the bottom door shelf could hold 2Lt bottles.
-- Edited by madaboutled on Friday 9th of February 2018 02:49:07 PM
