discover a comprehensive directory of free and low cost camps check out our comfortable cushions check out the new remote control Jockey Wheel Lithium Batteries Learn more about Sat Phone Sales Learn more about our special Townsvile rates Learn more about our Pet Travel Accessories Learn more about our CPAP machines designed for caravans
Post Info TOPIC: Jacking Screw Lubrication
Hi all,
Like many, I use a battery driven rattle gun to extend and retract the stablisers on our Pop Top.
My question is, what is the consensus on lubricating the threads, bearing in mind road dust etc possibly contaminating the lubricant and creating a type of grinding paste.
I was thinking either a dry PTFE type lube or a chain lubricant similar to a bike chain.
Any input would be appreciated.
John.smile
John & Lynda
The world is a book, and those who do not travel read only one page
If the screw is visible and easy to access then Graphite Powder will not attract dust like other oils and greases.
Graphite powder is messy to use.
Geoff
Travel Safely
Thanks Geoff,
Really good idea.
I just don't want the threads to pick up. Graphite sounds ideal.
John & Lynda
I used to use Lanotec but now use a silicone spray. Works very well, does not attract dust etc and it last for a long while before needing to re-do it.
White marine grease if you donât like graphite grease mess . I have both . We used graphite grease in electrical industry and marine grease on ABS . ( air break switches ) on contacts etc .
Actually way back in dairy farm we used mutton fat . It sticks like crazy .
Hmmm, mutton fat? 2 KG of best beef dripping please .
Thanks for all the replies.
John & Lynda
that abbotoir that went up in South Aus must have had plenty of mutton fat, All day to put it out
Cheers Craig
Save some from your chops . Ok lamb . Same same . Very good on leather saddles etc strap it around thread . It slowly melts . Doesnât smell .. Donât boil it down . I spray 50/50 ( maybe a little bees wax ? ) linseed oil and turps on under tray areas to ward off rust etc . It works as dry lube too .
Thanks for that. I like the organic solution.
Had a good look at the problem yesterday. It's easy to get to the front stabalisers and treat the thread, but the rear ones look like a royal pain in the proverbial.
I looks like they would have to be dropped off the van, treated and then fitted back.
I'll take a good look at this when I get back from this weekends little sojourn.
Thanks again for the feedback.
John & Lynda
Then you can eat it if you're feeling peckishbiggrinbiggrinbiggrinbiggrinbiggrin
Blues man.
Remember the leather ring that they put on front bike axles to keep them clean ? The same applies here .
Thanks for sharing these thoughts, I like the idea of the fat from chops being a good multipurpose lube and for sealing leather... Good advice, I will remember that!
Yeah it would be excellent in attracting vermin.
Kebbin
Yea two legged .. lol
