discover a comprehensive directory of free and low cost camps check out our comfortable cushions check out the new remote control Jockey Wheel Lithium Batteries Learn more about Sat Phone Sales Learn more about Melbourne City Caravans Pet Accessories
Post Info TOPIC: Compressor fridge V 3 way .
We have been away free camping over a week now . The  new Vitro 230l fridge freezer works a treat ! No more switching over to gas, checking temps .. It just works and does its job . Batteries are full charged on float be 10am . Its marginaly lighter than old 3 way yet slightly larger capacity . I can just hear compressor but doesnt annoy me at night .. One of the best things I have changed. Nothing like set and forget temp and running .
Hi Graeme
Well done mate saves an lot of LPG
of how many batteries and solar do you run the fridge If I may ask
Regards John
I wonder how many 9Kg bottle refills (each fortnight or so if using gas 24hrs/day/7days a week) it would take to equal the cost of the solar panels and batteries and any installation required.
Jest sayin' confuse
DAC7D221-D3D1-464D-912E-AE82010251DA.jpegLPG lasted about 2 weeks . Ok if on east coast . But 9kg bottles get pricy out west . 400 watt solar and 320 AH batteries. 60 amp charger when generator is started or on 240v mains . Doesnāt need main or generator ! We often start it to boil jug rather than use LPG . Generator is diesel and uses fuel from main motor tank . So no issues refueling seperate tank . The main thing it OPERATES like a fridge freezer should ! Lettuce lasts over a week now ! The ventilation for 3 way helps compressor work more efficiently over the portable 50l Dometic . Only 10 Watts more power consumption considering the size difference . I wrapped the rear of fridge with insulation before fitting . Removing and fitting through window wasnāt as hard as I though ! Did it mainly myself . Mrs helped getting old one out .
-- Edited by Aus-Kiwi on Tuesday 7th of November 2017 08:58:38 PM
It looks like I may be going down the track of installing a 110 litre 12 volt compressor fridge, in the not to distant future, AK
It is the only fridge of that size, (I could find), which has a real, and not a salesman "T" climate rating
Can you tell me what type of insulation you wrapped around it
Itās was some left over stuff we put under floating wood floors . I also used it doubled up inside old bus conversion on inner walls . As fibreglass tends to hold dust & moisture . Which results in rust .
This https://www.bunnings.com.au/qep-gold-laminate-floating-floor-underlay_p6650149
Thanks for that link, Aus-Kiwi
I shall have a look, next time I go to Bunnings
