Post Info TOPIC: Cetek d250s dc dc charger.
I don't know whether I am just getting too old or if I  am just missing something but I thought that battery chargers were meant to charge flat or low batteries. I just bought a cetek d250s dc dc charger for my caravan along with a 200 watt solar panel and I do a lot of bush camping.
When I installed the new system I could not get it to work on solar which I found out later it was because the caravan battery was below 13.3 volts which to me is near fully charged.The reason is that the cetek is also a battery isolator which I can understand it to protect the car battery from going flat but to restrict the solar charging is ridiculous. Now I have had to by a 240 volt charger and a generator. If I stuck with a basic isolator relay and solar panel regulator as I have done in the past Icould have saved a lot of money. Anybody got any suggestions.
regards. Bobhod
bob hodkinson
Are you certain Bob? That seems an extremely high cut-off for commencement of charging. Anyway... depending on the panel specs, an extremely cheap "make do" solution would be to connect the solar panel to the battery directly, and disconnect it before the battery voltage reaches its maximum allowable voltage. The battery will pull the panel output down. More practically, a different solar charge controller that doesn't have the same limitations could be purchased... however I honestly think there's a misunderstanding at hand.
I am not an Automotive Electrician, Bobhod
You may have a faulty item, or it may not be wired correctly
I have a Cetek D250S dc to dc charger
I have a motorhome where the chassis is hollow and galvanised (or perhaps silver phos paint)
As I was not sure if I could make a permanent good earth, I used the battery earths, as per the picture below
Using an el cheapo multi/clamp meter, I can confirm that my DC/DC charger works as manufactures description
I have had it perhaps nearly two years, and purchased it because I thought, it is a fit and forget item
1. The solar and/or engine battery, charges the leisure batteries, through the DC/DC charger
2. With the engine not running, after the leisure battery is fully charged, the DC/DC charger, allows the solar side to charge the engine battery
3. At night time with no sun, and no engine running, the DC/DC charger isolates the engine and leisure batteries
I found that using 6mm square cables, I did not have enough threaded length, of the Allen head bolt, to put all three earth wires onto the DC/DC earth terminal, so I made a bus bar by flattening a larger connection and drilling a hole in it
If the DC/DC charger is working correctly, and/or the wiring is correct, you will not require anything else to charge your leisure battery/s
I have one 300 watt solar panel, and two 120 amp house batteries
Hope that this info is useful to you
bobhod wrote:
...... it was because the caravan battery was below 13.3 volts which to me is near fully charged.
 Statement does not make sense to me.   I have three D250s and reckon they are a great bit of kit.   Maybe someone who knows somthing about setting up a Solar to 250S to battery System Needs to have a look.
Iza
Iza
Hi bohod,
I agree with Tony - something has failed or there's a wiring error.
I don't suppose you have a separate regulator stuck in there somewhere? Two in series will block the charge.
13.2-13.5v is the float voltage of a modern Gel/ATM battery. There is a good post called "Doing the Maths" just a little way down the Techies posts that gives the voltages you should expect.
I have a D250 DC-DC charger under the bonnet of my car - replacing the simple relay that overcharged the auxiliary battery in high temperatures, risking an explosion. It has definitely improved the life of that battery & given me peace of mind.
Check your wiring, if necessary rewire to Tony's diagram & if you still cannot get it to work, ask an auto-electrician to check it out.
All the best,
I have a 250s dual in my tug to charge the fridge battery. It is connected to the alternator & a 90 watt solar panel. I also have one in the van. It is only connected to a 120 watt panel. Both work fine. They bulk charge above 14 volts. They float charge around 13.3 volts. After a period of float charge they disconnect the charge, & battery voltage drops back to around 12.9 volts. This only happens if no load. As soon as any load is applied the charge reconnects. Try applying a load & see what happens maybe your battery is fully charged. I am very rarely connected to 240 volts. My batteries are always charged.
Thanks Tony I fully agree with you. cetek equipment is excellent but I believe that with the d250s they have got it a little wrong on the solar charging by not letting the solar panel charge if the battery is below 13.3 volts as this is when you need the solar panels charging. The cetek works like a normal twin battery isolator in as much as it is basically an open circuit until the starter battery reaches 13.3 volts and then it closes the circuit and lets the alternator charge the caravan battery charge, this is to prevent the starter battery going flat. But in doing this they have also created an open circuit in the solar charger section which prevents the solar panel charging the caravan battery until the battery is at 13.3 volts.
my wife ang I like to watch a bit of TVs at night and with the fridge running the batteries would generally be ar about 12.5 volts in the morning so the solar panels are prevented from charging the batteries which means that you either have to run your engine or use a generator to get your caravan battery up to 13.3 volts ln order for the solar panels to start charging.
The only way to fix the problem is to disconnect the solar panels from the cetek and cooect them via a seperate solar regulator direct to the battery.
best regards
bob Hodkinson
bob hodkinson
Bob, you are describing the same setup that I have in my tug. After stopping the engine, the ctek will disconnect the start battery the first time the fridge runs. I could sit for 3-4 days with out starting the engine. The solar panel keeps the fridge battery charged. If the fridge battery gets fully charged, the ctek will reconnect to the start battery & divert any solar charge to the start battery.
Bob, sometimes when I travel, I am up before the dawn
I have seen my leisure batteries as low as 12.7 volts
As soon as the dawn comes, the solar panel starts charging the battery, through the Cetek D250S DC/DC Charger
The only leisure battery charger I use, is the same make and model, as the one in the picture
Thanks Tony that seems really positive and is just what I want. I have my d250s mounted in the caravan next to the caravan battery and everything is wired up as per your diagram. The only thing is that the car is parked away from the caravan so the 12v from the car is not connected to the caravan. But I believe that the solar system should still work like you said. At the moment I have fully charged the caravan battery with a seperate charger and rhen turned off the charger and turned on the frig. I note that the solar panel will not connect and start charging because the battery is fully charged but I will keep watching it all gay and see what happens. I will keep it running until the battery goes flat and let you know what happens
Bob
bob hodkinson
Do not let your battery go flat, Bob
When you have dropped down to 12.4 volts, you would have taken plenty out of it
You are correct that in a normal situation, the solar side will work with no engine battery connected
I always isolate my engine battery, when doing maintenance on the engine, and the DC/DC charger still works
Below is a bit of a pic, on how I check mine with a cheap multimeter
If you do not have numbers within this ball park, you may have to get an auto sparky to look at it
Or perhaps a techi will come along and explain it better than me, as I am not an Auto Electrician
Also make sure polarity across solar input and negative correct from panels
 Just this morning, I connected a 250S to a battery reading 11.9 volts.    300 watts of solar panel feeding in to the 250S has popped the battery up to over 13 volts already.    This is completely at odds with the assertion that no charging happens until the battery to be charged is at or over 13.3 volts.   A rested battery reading 13.3 volts, open circuit, does not need charging.
Iza
Iza
