Post Info TOPIC: Water tank cleaning
Water tank cleaning
we have just purchased a van thats sat idle for the past 18months, what solution or chemicals is good to give the 3 water tanks a good clean.
appreciate any feed back..
What are the tanks made of ? Mine is 200 L Pure Aluminum and is filled with a gluey oxide sludge. I cant vouch personally but my mate who is invariably right about these things gave me 375 ml of CLR which I will fill the tank up and add. Let it slosh around for a day or so , drain and flush.
HTH
MZ
And I somehow rather fancy that I'd like to change with Clancy ..
The Happy Helper
No way would I put CLR into a drinking water tank! ok in the grey water though. Have heard that cheap red cordial put into your drinking water tank, leave it to slosh around for a day or so, flush, and it will be fresh again. (At least three x 2 litre bottles. with some water)
jules
(Ben, aged 10)
Firstly, welcome to the forum Charlie
This is one source of advice ...
Water tank cleaning - click here
Welcome to the gang Charlie, enjoy here and out in the playground.
I only a few moons back put a bottle of Milton in the tanks and filled with water, I let sit for two days then drained and flushed. Normally you would drive around a bit to 'swish' it around but I was set up at the time.
Milton is used to wash out baby bottles so should be safe. I also don't drink the tank water and if I did, but I don't, it goes through a filter under the kitchen sink first.
Thanks for the tip....
A warm welcome from me also, Charlie
My second hand caravan, and then my motorhome, were in the same condition as your caravan, (not been used for many months, before I purchased them)
I drained the water from the tanks, filled them with fresh water, drove around a bit and emptied them, I did a few times, until the water became clear
Although I use bottled water for drinking, I (like many others on this forum), have a B.E.S.T. filter on my food grade water hose, when filling my tanks, (just in case)
I did read many years ago that some Australian Aid Organisations, used red cordial in the water, when they go to undeveloped countries, as it kills some bacteria
I have seen some sort of chlorine in some camping shops, to clean the water tanks, but have never used it
Yep I've added about 1/2 litre chlorine. Drove around and left overnight . Drained and filled with 2 cups of bicarbonate of soda . Drove around cycled through taps . Then drained the next day . Then 1/2 filled with tap water .. Drove around the block again . Then filled one last time with fresh filtered water . Did this when I bought motorhome. I havn't bothered doing any chemical cleaning the last 5 years . I just keep cycling fresh water through often . Enough chlorine in tap water to keep fresh . I hope ! Aha . Have double filters on main and another finer filter on seperate drinking water tap !
Yeah I don't like drinking water from the Van tanks and I don't like the rinsing the tank with chemicals ,the tanks are for showers washing up loo ect and we carry a supply of good quality drinking water in the car...
Me too ! It was on purchase and you don't know what was done before ? We put similar amounts daily in our pools . I don't add to drink . Just used chlorine to sterilise tank ., Most our drinking water is boiled anyway . Check the sodium / salt in some water bottles .
Hi all, Just my 2c worth.
Chlorine is good, after all, I use it to kill bacteria in the pool and it's added to drinking water. But a cheaper alternative is white vinegar. Add a 1L bottle to your water tank, 1/2 fill with H2O then allow to sit and slosh as described above and then flush through pipes and drain out of tank. It's a nice friendly solution to both humans and the planet.
John & Lynda
The world is a book, and those who do not travel read only one page
Perhaps try domestos. It's about 10% sodium hypochlorite. It's added to our water supply. I would add about 250ml and half to three quarters fill the tanks. Drive around and then rinse well. Will kill a NT Buffalo.
Sta
Believe it or not they use percarbonate of soda to clean beer lines in clubs,pubs etc
People worry a bit too much about some of these chemicals. Providing you wash/rinse the tank well after using it will be fine.
Sta
I remember reading that the ancient greek army used wine to purify their drinking water, worth a try anyway, and white vinegar seems in the same vein.
Also the Lions club I belonged to used vinegar to sterilise preparation utensils and cutting boards at their regular sausage sizzle.
"I contend we are both atheists, I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours."
...Stephen F Roberts
-- Edited by jegog on Wednesday 27th of February 2019 08:08:30 PM
Heaps of salt,,,,,
fill tanks to say 25% with water go for a drive,,, empty and flush a couple of times.
