I agree with blaze, a quick tap on the over ride will do the trick, then slow down a bit..
X2. Do not try and accelerate your way out. Unless you have a vehicle capable to doing the 1/4 mile in under 10 secs, you will make it worse. Also ignore the temptation to apply the brakes on the tug.
I was wondering if the van was favouring one side over the other, for example when it starts does it always sway the same way. My reason is if it is favouring one side over the the other then you may have a loading issue causing it to move that way or it could be a suspension issue or even tyre pressure. Regardless, you may be able to track down the issue or at least provide some info to a repairer.
More importantly best of luck and when you find out lets us know.
Seriously though it is usually a loading / balance problem fix that should help lots
When the power of Love becomes greater than the love of power the World will see peace ! 24ft Trailblazer 5th wheeler n 05 Patrol ute and Black Series Dominator camper trailer ( for the rough stuff)
I haven't had a problem, was just enquiring in the advent of this situation arising, one good bit of advice is to trial with manual brake setting/lever [practise], from time to time, in the advent of it arising there would be no panic, good idea, cheers
