Post Info TOPIC: Where to store your hitch bars without getting grease over things.
 I've always had a problem of where to store the hitch bars without the ends getting grease over things when I get to the site.
By reversing the bars the other way and hanging them just under the A frame on a sling solved the problem.
If I'm in a area that could be a bit suspect I run the high tensile wire through the chains that I use to lock up my sat dish & solar panels.
A good cheap fix that didn't require drilling holes that worked for me.
Cheers, - John
Very good idea John. Always good to see tips like that. Thanks for shareing and the pic.
like you idea for storing the rubber mats as well
We use a pair of woolen socks, stretch open and place each over the greasy end and store where you like.
I use old work socks for storing ratchet straps. You can usually fit a pair of ratchet straps in each sock, and it stops them getting all tangled. Looks funny with my workboots and no socks though. hmm
Thanks John, great idea
Live long and Prosper
On our Jayco there is a box channel across the front of the van and I slide them in chain end first, out of the way and out of sight
Thanks Happy Camper... John.
I will do exactly the same with the sock cover added.
Jay&Dee
