SmartBar SmartBar
Post Info TOPIC: Caravan electric jack
Just bought one of these and very impressed with the response to questions and service so hopefully the item will be as good. The postage has increased by $20 since yesterday but still reasonable.
http://www.ebay.com.au/itm/300935913205?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Cheers Jeff
Jeff - how are you going to mount it?....
Sorry for the delay Denis I forgot to hit the subscribe button. I intend to bolt/weld (probably bolt) a steel plate across the A frame and mount it on that. It will need to be slightly offset to clear the hand brake cable but looks do-able. It is in transit at the moment.
Cheers Jeff
I just use a portable jackall jack,got me out of trouble many times.
Happy Camping
Graeme
I was always taught to respect my elders,
but it keeps getting harder to find one.
I have a Trail-A-Mate jack which I have used as a jockey wheel and jack when/if I need one but had it fail on me. The electric one has a handle that you can use to crank it if there are any electrical problems. It's at the PO now and I'll be picking it up tomorrow.
Cheers Jeff
Finally got it all finished now and very happy with it even if it is a little slower than I'd imagined but it's not an issue.
Cheers Jeff
I have one of these elect jack,s had it for a couple of years now, just sorry I didn,t bye the one with the bigger weight the one I have is doing the job I bought it  for the same as you ,I bought an attachment to use it as a jack if I got a flat tyre but it wont lift the van high enough, never mind it is doing the job I bought it for .
Lance C
