SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Portable Oven
Portable Oven
Bought a Russell Hobbs oven the other day to take on the road, did some baked veggies in it last night, they were great, have done salmon fillets, pies,  frozen fish, chips in it as well, all good.
Got to thinking, would this oven use less power than a conventional household oven. It's 1300 watts. It gets to the required temp quickly, not like our oven in the kitchen.
Just thought someone out there could give me the thumbs up or down on this one
Never get so busy making a living
that you forget to make a life
We have a Casera , paid $39 it's rated at 1400 watts and cooks anything from roasts to pizzas, bread and biscuits. When it breaks down, I'll go back and get another for $39.
Larry
-- Edited by deverall11 on Tuesday 11th of March 2014 03:50:28 PM
-- Edited by deverall11 on Tuesday 11th of March 2014 03:50:48 PM
I have two of these different brands one is cheap Casera and just as good as the original which was expensive.
I only turn the oven on at home now if I have a mob to cook for. Even then I sometimes use two of these. Recommend to anyone they are great
Mim
Dig a hole in ground, put some rocks in hole. Set a good fire. While its burning rap chicken, pork, pumpkin, sweet potato kumara in cabbage or palm leaves . Clean burning wood out of fire . Lay wire netting over hot rocks and throw rapt food in hole over wire netting . Quickly cover with old wet sheet . Add about a litre of water and fill with dirt .. Keep adding till steam stops moving out,, wait 4 to 5 hours .. It should start smelling from 2 or 3 hours .. When time Is up cross fingers and clean off dirt.. Pull off sheet which should hold or separate dirt .. Pull food out with wire mesh .. Best if a little burnt.. Smoked and steamed food..
Yum you've just made a hangi .. Sorry to go off topic .. But it is an oven of some sorts.. Aha
 .....or ring Dominos!biggrinbiggrinbiggrin
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 21' Silverline 21-65.3
' 1260w Solar: 400ah Lithium Battery: 2000w Projecta IP2000 Inverter
Our previous van did not have an oven so I snavelled the small electric oven when we sold up my Mum & Dad's house after my Dad passed away and Mum went into a nursing home - it is the most fantastic little oven I have had. I also use it in the house as it uses less power (and does not heat up the house) than my big stove. Considering that there is just the two of us, it is great. It is a Kambrook oven. It used to sit on the seat in the van and never moved an inch as we travelled. Now though, with our new van got to learn how to use a gas oven!! Not used one of them before!! As they say, you are never too old to learn something new.
Pejay are travelling in a 2014 Holden Colorado LTZ Twin Cab Ute + 2013 Coromal Element van
I have the Aldi oven and it is simply great - beautiful pork roasts with crackling, lamb, beef, veges. And I always use a meat thermometer.
But the 'van is also fitted with a multifunction microwave - Sheffield PLA0520 which also grills, roasts. bakes and even is a breadmaker. I've only tried the grill once but got impatient waiting for the bacon to grill biggrin. I have used the oven to make my deeelicious date loaf (using weetbix). I use the Aldi for roasting.
I guess when I hit the road in May I'll use the Baby Q for mroasting, although I'm tempted to buy a 2kva genset so i can do use the m'wave or Aldi.
The secret to a good old age is an honourable pact with solitude - One Hundred years of Solitude
'96 Jayco 15' Westport potop/ Prado GXL turbo diesel
 I notice the Maori's I know now use a "Hangi" Pot.   Usually made from  a couple of beer kegs.
They are getting closer to realising  there are Microwave Ovens out there.
"Keep New Zealand Green"         Tell    them nothing.
I do enjoy a good Hangi,     I used to live in NZ for 20 years and had a lot of Maori friends and neighbours.
Mike & Ellie
Same same .. When we cant dig a hungi or light a fire..
-- Edited by Aus-Kiwi on Thursday 20th of March 2014 01:27:51 AM
msg
I bought a $40 convection oven from KMart. Works well. In fact, I had to by one for the van and another for the house. Gets used every day. Can cook everything that you would use an oven for, and runs on a small generator.
