SmartBar
Post Info TOPIC: Stress management
Stress management
A young lady confidently walked around the room while leading and explaining stress management to an audience with a raised glass of water. Everyone knew she was going to ask the ultimate question, 'half empty or half full?'.. She fooled them all .... "How heavy is this glass of water?" she inquired with a smile. Answers called out ranged from 8 oz. To 20 oz.
 She replied , "The absolute weight doesn't matter. It depends on how long I hold it. If I hold it for a minute, that's not a problem. If I hold it for an hour, I'll have an ache in my right arm.
 If I hold it for a day, you'll have to call an ambulance. In each case it's the same weight, but the longer I hold it, the heavier it becomes." She continued, "and that's the way it is with stress.. If we carry our burdens all the time, sooner or later, as the burden becomes increasingly heavy, we won't be able to carry on."
 "As with the glass of water, you have to put it down for a while and rest before holding it again. When we're refreshed, we can carry on with the burden - holding stress longer and better each time practiced. So, as early in the evening as you can, put all your burdens down. Don't carry them through the evening and into the night... Pick them up tomorrow.
 1 * Accept the fact that some days you're the pigeon, and some days you're the statue!
2 * Always keep your words soft and sweet, just in case you have to eat them.
3 * Always read stuff that will make you look good if you die in the middle of it.
4 * Drive carefully... It's not only cars that can be recalled by their Maker.
5 * If you can't be kind, at least have the decency to be vague.
6 * If you lend someone $20 and never see that person again, it was probably worth it.
7 * It may be that your sole purpose in life is simply to serve as a warning to others.
8 * Never buy a car you can't push.
9 * Never put both feet in your mouth at the same time, because then you won't have a leg to stand on.
10 * Nobody cares if you can't dance well. Just get up and dance.
11 * Since it's the early worm that gets eaten by the bird, sleep late.
12 * The second mouse gets the cheese.
13 * When everything's coming your way, you're in the wrong lane.
14 * Birthdays are good for you. The more you have, the longer you live.
16 * Some mistakes are too much fun to make only once.
17 * We could learn a lot from crayons. Some are sharp, some are pretty and some are dull. Some have weird names and all are different colours, but they all have to live in the same box.
18 * A truly happy person is one who can enjoy the scenery on a detour.
19 * Have an awesome day and know that someone has thought about you today.
AND MOST IMPORTANTLY
20 *Save the earth..... It's the only planet with chocolate!*
I like number 6 best: If you lend someone $20 and never see that person again, it was probably worth it.
In my case if I lend someone $20, I never see the $20 again but I still see the person.
Some good things to think about there. Good Stuff.
The Happy Helper
No. 20 is my favourite!!!!!
jules
(Ben, aged 10)
A very good analogy... and witty.
Gary
Re no. 6
A  lesson from my Dad: I'll lend you 10/- (when a pot cost 9d) and I'll never ask for it back. but if you don't repay it, never ask me again.
N.O.M.A.D.  Normally only me and dog.
This is all fantastic, but I relate to number 18 best... have done a lot of that
Cheers,  Gerty. ... at home
Must own up to it being no.2 for me. Took me a long, long time to get that through my thick headwink
Proud owner of an 2006 3lt turbo diesel Rodeo. Van will be next!!
No. 4 is a scary thought...never thought about it quite like that.
Excellent thanks for posting it
Thanks for posting this spida.
NeilnRuth
