Post Info TOPIC: "Linkify-ing" URLs
"Linkify-ing" URLs
If you're like me and you prefer to use the Quick Reply box, you will be annoyed whenever you need to include a URL in your post. That's because you need to use the Advanced Editor to "linkify" the URL.
If you would like to avoid the annoying clickfest, then you can manually input the appropriate BBS codes. Remove the spaces in the square brackets to see what I mean.
[ url ]http://thegreynomads.activeboard.com/f593698/hints-tips-and-great-ideas/[ /url ]
BBS = Bulletin Board System
BBS codes and HTML tags are hidden control codes that tell the forum software how to display your text. When you select the Advanced Editor, these codes are inserted for you. For example, when you select Bold or Italic, the editor adds "b" and "i" codes enclosed in square brackets.
To illustrate, cut and paste the following two lines into your reply box, and remove the spaces from within the square brackets on the second line only.
[ i ]italic[ /i ] plain [ b ][ i ]bold italic[ /b ][ /i ] plain [ b ]bold[ /b ]
Then select Preview.
-- Edited by dorian on Saturday 25th of May 2013 06:21:00 PM
Bit of foreign language there Dorian - what's BBS and what's the url in the square brackets for? Can you explain it a bit more please.
some of us are not as techno as others and need more detail in the explanation, Thanks
mmmmm OK got ya.
                          A day without sunshine is like, well, night.
And the difficulty in opening the advanced editor is WHAT!!!!. I personally find the lack of options coming up in the first instance when using the quick reply mode a pain at times especially if I have pics or drawings to attach but I just chill and get on with it. Treat posting as type of therapeutic outlet and release not a vocation
I don't use the quick reply, because my replies aren't usually quick! biggrin
If I want to add an address, I just bring it up in another window, highlight the address and copy and paste.
Too easy! wink
Too easy! wink
 I could be wrong Beth, but that address method still does not "linkify"...at least not when I tried it.
Even when you cut and paste a link you still need to 'activate' it by hight lighting and clicking on the 'chain' link as in my previous post. Seems much quicker than deleting brackets etc - one click does the job.
You don't need to delete brackets.
It looks like automatic "linkification" is now available. I assume there must have been a forum software update.
Just testing (without BBS codes) ...
www.thegreynomads.com.au/
Its easier to just click on reply in the first place, then copy and paste. You do need to click the space bar or "enter" at the end of the link.
Cheers,  Gerty. ... at home
