Post Info TOPIC: Links not clickable
Links not clickable
I cant seem to make my links clickable what is the secret.Yes Vic41 i did try your suggestion it didn't want to work for me.They all come out like the one below.
http://www.thegreynomads.com.au/featurespages/SOLO.htm
-- Edited by Stefan on Monday 14th of September 2009 09:22:52 AM
Hi Stefan
It appears that the 'insert link' function has been disabled for some reason.
Not your fault.
Cheerrs
Neil & Lynne
Pinjarra
Western Australia
I'll just repeat it Stefan,
Once you have posted as per your above post and the link does not work, click on your edit button (you have to be patient, it says done but then keeps loading) and wait until all the wording on the edit page has stabilized, then put your mouse pointer directly behind the last digit/letter of your link, left click and make sure the "marker" is showing behind he link, then hit your space bar once, the link should then show up in blue/purple, the hit submit post at the bottom of the edit page and it should work.......try it again.
Hope it works this time for you,
Vic
-- Edited by Vic41 on Monday 14th of September 2009 09:15:16 AM
      Vic
"Sunset Coast"
Member - Australian Touring Caravan & Motorhome Club
www.atcmcc.org.au
Hi Vic,
I am having the same problem as Stefan, have tried your suggestion but don't work for me.
I can't highlite my blog address in my signature block neither.
http://garykerrystraveldiary.blogspot.com/
htttp://garyandkerrys2009travels.blogspot.com.
Port Noarlunga SA
Experience is something you don't get until just after you need it.
Try this one, Gentle People.
Type the URL into your message, highlight it, the link icon above the message panel will become active, click on the link, a drop menu will appear, enter the link into the appropriate box, voila!
test run
Thanks Rolly
-- Edited by Gary and Kerry on Monday 14th of September 2009 07:00:47 PM
-- Edited by Gary and Kerry on Tuesday 15th of September 2009 09:09:50 AM
Port Noarlunga SA
Ma
works Gary and Kerry,   thanks.   good read.
Guru & Ma
Ulladulla NSW
Happy day, safe travelling
Ford Ranger towing 21ft Jurgen shower and toilet which was large enough to fit in a few extras (fridge, bed, stove...)
Thanks Rolly, beats the way I was doing it. I notice at the top and bottom of the pages of the forum that it has the comments "Links not Clickable", I wonder if this is meant to be like that to prevent spam/hackers etc on the site?
      Vic
"Sunset Coast"
www.atcmcc.org.au
Nah, Vic.
It means that it's the topic name on the general forum of the Grey Nomads forum.
DUH !!!! Thanks Rolly, I'll crawl back into my hole now, lol !
      Vic
"Sunset Coast"
www.atcmcc.org.au
Testing 123 testing 123
Yehaaaa i think that Linky thingy button works
Yes it does work Thank you biggrin
-- Edited by Stefan on Tuesday 15th of September 2009 05:00:53 PM
