I bought a 12 volt cigarette socket lead (plugs into the Starlink dish) off the eeeeBy mob .
So it will power your Starlink Mini if you get two 12 volt batteries hooked up to make 24 volts .
BBN2 said
02:40 PM Aug 13, 2025
The Starlink Mini will operate from 12V but do not use the supplied 15m cable, it is too light and the voltage drop too high. Jaycar do an adaptor with heaver cable.
Starlink info
12 volt cigarette plugs have a habit of working their way out.
Far better to use an Anderson plug.
