Had mine in since 2007 and solar had no glow plug issue. My thought, when do you need spares
Neil
PeterInSa said
07:54 PM Apr 11, 2025
Had trouble starting the heater in remote Bush, changed the Plug and the screen all good. Most likely it was a screen clogged problem. Just wanted the problem solved, hence the 2 changes.
Greg 1 said
02:39 PM Apr 13, 2025
Run some kero in your diesel once in a while.
It tends to stop them sooting up.
I add about 250ml to 5 litres of diesel.
Any difference between the 2kw, 5kw and 8Kw Glow Plugs , looking at a back up for my 2Kw unit, just in case need a change in the bush.
https://www.aliexpress.com/item/1005006856088180.html
Neil
