Update solar, battery, inverter or portable power?
NoelB said
02:30 PM Jan 21, 2025
Hi Techies. A little similar to the post by 'ottg' but a slightly different angle - my van has a 100w solar panel, 100 Ah AGM battery and no inverter.
I'm after approx 350w solar, 240Ah lithium battery, 2000w inverter.
Am I better off going this way or looking at a portable power station - Bluetti, iTech World, of comparable power output? (+ solar blanket).
Thanks for your two bobs.
Noel
-- Edited by NoelB on Tuesday 21st of January 2025 03:32:30 PM
Peter_n_Margaret said
03:28 PM Jan 21, 2025
In my experience, so called "power stations" are very expensive boxes of bits you probably don't need connected to batteries of unknown quality.
Choose quality components of the capacity you actually need and connect them in a quality manner in order that you can update or replace individual bits in the event of failure or changed requirements.
NoelB said
03:33 PM Jan 21, 2025
Thanks Peter
Jaahn said
07:57 PM Jan 22, 2025
In my experience, so called "power stations" are very expensive boxes of bits you probably don't need connected to batteries of unknown quality. Choose quality components of the capacity you actually need and connect them in a quality manner in order that you can update or replace individual bits in the event of failure or changed requirements. Cheers, Peter
I agree with this as well ! Jaahn
valiant81 said
09:49 AM Feb 5, 2025
Hi all; NoelB, The 350 Watts of solar, may be a bit on the light side, and if you can afford it go for a bigger Lithium battery ( i have a 300 Ah and have power to burn ). But may main question is why do you need a 2000 Watt inverter for ???
Noel
Thanks Peter
Cheers, Peter
