My furrion underbunk wont keep up when cooling on a 30 deg day outside it still gets to 27 in the van. Its only 16 ft poptop so not big the air is cold coming out of the vents is it a waste of money
Dick0 said
09:56 AM Jan 4, 2025
Correct ducting seems to be very important with these underbunk aircons.
phum said
12:04 PM Mar 10, 2025
My furrion is hopeless too . It's so.bad I thought it was faulty my ducting is to spec it blows but its probably a better heater than cooler. Note to self. Don't believe advertising or seller blurb if you can't try one Don't waste money
DeBe said
02:33 PM Mar 10, 2025
Air con on the floor is the wrong place as cool air doesnot rise. My diesel heater is mounted under a bunk, being hot air it rises & heats the van. My air con in a 14Ft poptop is only small but is mounted in a window & does the job well.
jjellfern said
08:26 PM Mar 31, 2025
Had a problem with my aircon not cooling for more than a few minutes. Turned out to be mud wasps built in the condenser fan preventing it from turning.
