Hi Travellers Has any one had experience in changing a rear diff pinion seal on an Iveco, the quote from Iveco, was to say the very less " A faction Under the Bloody Nation Debt" .
-- Edited by rgren2 on Monday 16th of December 2024 09:13:31 AM
Peter_n_Margaret said
10:57 AM Dec 16, 2024
So what was the quote?
If you are not competent to change it yourself, you will need to pay someone else to do it for you. Any competent mechanic can do it.
Joda said
07:15 PM Dec 16, 2024
I,ve done a few in the past, the yoke nut has a very high torque to start with, some diffs have a collapsible spacer to set the pinion preload, you need a special tool that measures the force to rotate the yoke, this sets the pinion to crown wheel engagement, take it to a diff specialist, diffs are expensive to replace or rebuild.
Justalad said
07:42 AM Dec 19, 2024
Thanks for the reply's
Iveco quoted Labour only $677
Have found a Mech specialising in Iveco's who can do it for $150 about 1 1/2 hours work
watsea said
10:32 AM Dec 19, 2024
Justalad wrote:
Thanks for the reply's Iveco quoted Labour only $677 Have found a Mech specialising in Iveco's who can do it for $150 about 1 1/2 hours work
Looks like the Mech specialist is going to get a job. Good luck with the diff.
As for the quote from Iveco, and people wonder about the causes of inflation.
I have managed to procure a seal, Genuine Part
Any Advice would be greatly appreciated,
Safe travels
Cant be much different to this.
www.youtube.com/watch
https://www.youtube.com/watch?v=0Gpl6D76vzc
All sorted $163.00
