My new Surburban HWS is due to be delivered today.
I am thinking of using a work around to solve an issue, instead of connecting John Guest hose and fitting directly to the water inlet and outlet, would it be feasible to use stainless steel braided hose and then connect to JG.
The reason I am thinking about this idea is where the Hws is located, you need to be a bloody contortionist to replace JG hose in it gets a pin hole.
FYI the Hws being replaced is 240v only it has only lasted 5 years because of the bore water, an annode generally lasts about 6 months.
Possum3 said
08:10 AM Jul 22, 2024
Fortunately, the heater in my Evernew was plumbed in with copper tubing so no worries on that front.
With respect of poly-tube plumbing installed by unskilled labour at most manufacturers, it is not unusual for failures to occur that can have catastrophic effects in confined areas. It is normally not the product that fails but rather the faulty installation.
kgarnett said
09:00 AM Jul 22, 2024
Read this article about flexible hoses before you commit to using them.
https://plumbingconnection.com.au/bursting-the-flexi-hose-bubble/
Ken
Use PEX for hot water.
Yes Gundog, you can!
My previous caravan I did exactly that with cold water inlet and hot water outlet to Suburban HWS. Bunnings has variety of lengths.
I figured if they last (forever) connected to sinks/basins/troughs/cisterns at home there should be no problem in caravan.
My current caravan has these flexible hoses at the kitchen sink and vanity basin factory fitted.
In all my years of using these flexible hoses I have never ever had one fail.
But, I have had JG hoses fail several times.
