I have had a quick look over the document, government documents are never very easy to understand, others may have a better understanding of the document then myself.
From what I can see if you have had a GVM upgrade on your tow vehicle you will be able to increase the GCM to the same value as the new GVM.
It looks like the new regulations are retrospective, not sure on this, unless it only applies to pre registered vehicles,so have a look and please comment.
-- Edited by Farmhouse on Tuesday 21st of March 2023 09:26:03 AM
-- Edited by Farmhouse on Tuesday 21st of March 2023 09:27:17 AM
-- Edited by Farmhouse on Tuesday 21st of March 2023 09:31:09 AM
-- Edited by Farmhouse on Tuesday 21st of March 2023 09:32:41 AM
-- Edited by Farmhouse on Tuesday 21st of March 2023 09:33:58 AM
Possum3 said
09:36 AM Mar 21, 2023
Cindy wrote an article on this a week or so back on website.
Farmhouse said
09:39 AM Mar 21, 2023
Do you have a link please?
Possum3 said
10:18 AM Mar 21, 2023
I don't but I'm sure another member may be able to put it up, or PM Cindy.
Farmhouse said
11:16 AM Mar 22, 2023
I am surprised this post has not triggered a few comments at the least.
I do not know who Cindy is and I have searched and cannot find her past post.
rgren2 said
11:23 AM Mar 22, 2023
Cindy is the administrator, her post is probably in the home page.
yobarr said
01:19 PM Mar 22, 2023
One of the more salent points is that the vehicle must have a full ladder-chassis. None of these dreamer's machines with monocoque construction and the like. Hope this helps but all relevant information is easily found. Cheers
-- Edited by yobarr on Wednesday 22nd of March 2023 01:33:21 PM
the comments at the bottom of the article are interesting to say the least.
-- Edited by RickJ on Wednesday 22nd of March 2023 01:38:33 PM
Farmhouse said
05:39 AM Mar 23, 2023
Thanks RickJ and vobarr, this is what I was looking for.
Looks like the re rating is only applicable to light vehicles such as utes and light trucks.
Unfortunately our Mux misses out on the upgrade. Pedders are researching atm and will give me an answer soon.
Thanks for the links.
-- Edited by Farmhouse on Thursday 23rd of March 2023 05:49:41 AM
yobarr said
09:04 AM Mar 23, 2023
Unfortunately our Mux misses out on the upgrade. Pedders are researching ATM and will give me an answer soon.
Just a bit of advice. Wonder what you mean when you say that Pedders are "researching ATM" as ATM refers to trailers/caravans.
Recent model MUXs have a tow rating of 3500kg, but no one in their right mind would even dream of hooking up a 3500kg PIG trailer to an MUX.
Don't have exact figures on me at moment, but. seem to recall that an MUX is out of its depth towing much more than 2800kg as a PIG trailer.
Unfortunately the vast majority of nembers here have NO idea how tow ratings are calculated. 3500kg behind an MUX?
Tell'em they're dreamin'. Cheers
KJB said
09:13 AM Mar 23, 2023
"Tow Ratings " by Manufacturers refer to "Towing" (or "pulling" in simple terms) ......not to "Carrying some of the load and Towing the rest" (as per a Pig Trailer/Caravan) there is a BIG difference.
yobarr said
09:55 AM Mar 23, 2023
That is correct Kerry, and I have explained this in great detail in several earlier threads.
In my view this is a deceptive and dishonest way of issuing tow ratings, leading to owners of the popular twin-cabs and other unsuitable vehicles like LC200s thinking that they can safely tow 3500kg PIG trailers (caravans). They can't. Cheers
-- Edited by yobarr on Thursday 23rd of March 2023 10:01:22 AM
Farmhouse said
06:12 PM Mar 23, 2023
yobarr ATM also short for AT THE MOMENT sorry for the confusion.
Also our Mux is my15 so tow capacity is 3000kg.
With our GVM upgrade and air bags fitted I have no problem towing 3000kg.
Slotted rotars up front with Kevlar pads will also stop our setup.
Also tow ratings refer to tow bar towing capacity not vehicle towing capacity.
-- Edited by Farmhouse on Thursday 23rd of March 2023 06:14:19 PM
-- Edited by Farmhouse on Thursday 23rd of March 2023 06:15:26 PM
-- Edited by Farmhouse on Thursday 23rd of March 2023 06:17:46 PM
-- Edited by Farmhouse on Thursday 23rd of March 2023 06:27:21 PM
whatsa said
06:53 PM Mar 23, 2023
lol whats a mux?
yobarr said
07:13 PM Mar 23, 2023
Oh dear Glenn, you are terribly confused. Tow ratings refer to the legal, but not necessarily safe, limit of the vehicle's ability to tow a trailer. It is generally accepted, and simple physics, that the towball weight should be at least 10% of the towed vehicle's ATM. This means that if your MUX is towing a 3000kg ATM van, your towball weight should be at least 300kg.. Because of your 1075mm TBO ( towball overhang, or distance from rear axle to hitch point) the actual weight applied to your car's rear is around 400kg (+/-) . Your car has a rear axle weight at TARE of at least 1080kg, so applying 400kg to the rear axle increases that weight to 1480kg. Rear axle capacity is only 1600kg, but tare is weight of the car with NO driver, NO passengers, NO luggage, NO spares, NO weight of actual towing structure, so NO HOPE. Your GVM upgrade, as always, is virtually a waste of money because your rear axle carrying capacity increases to only 1650kg. A HUGE 50kg! Why bother? However, if you do have that GVM upgrade you can now safely tow your 3000kg ATM van, ONLYassuming GCM upgrade which I doubt you'd have? Could you please supply all figures from your GVM upgrade so that I can give advice? Cheers
yobarr said
07:15 PM Mar 23, 2023
whatsa wrote:
lol whats a mux?
Isuzu MUX, a good LIGHTWEIGHT car with same engine as Isuzu DMax, I believe. Good to tow up to about 2700kg ATM van. cheers
Farmhouse said
07:53 PM Mar 23, 2023
My dear yobarr, no, thats condescending so I would not use that term.
yobarr I am not confused at all, nowhere did I mention TBW ( tow ball weight) You are right with regards max GVM does not mean that the load is safe to tow. I have a certified QLD certified GVM rateing of 3200 kg for the Mux. Nowhere did I mention that the GCM or the towing capacity was increased. See original post and my following post. In Queensland youcan now, on some light trucks increase the vehicle component of the GCM. This can not be done on a Mux because the frame is not ladder like built, it states that quite clearly. Here is another FACT, no passenger vehicle has ever been fined for overloading under the AUSTRALAN road rules traffic act in any state ever.
I have been doing a lot of research on vehicle weights and regulations and I still do not have the right answers to all.
I am very confident that the setup on our Mux will tow, with care our new van when it arrives. I have spent a lot of time and money on achieving the tow vehicle I drive to achieve the best result. Yes it will struggle on hills like most do, but it will suit me just fine. I know you like a bit of banter so I hope I have succeeded with my quest.
Cheer
Glenn
yobarr said
08:19 PM Mar 23, 2023
8yobarr I am not confused at all, nowhere did I mention TBW ( tow ball weight) You are right with regards max GVM does not mean that the load is safe to tow. I have a certified QLD certified GVM rateing of 3200 kg for the Mux. Nowhere did I mention that the GCM or the towing capacity was increased. See original post and my following post. In Queensland youcan now, on some light trucks increase the vehicle component of the GCM. This can not be done on a Mux because the frame is not ladder like built, it states that quite clearly. Here is another FACT, no passenger vehicle has ever been fined for overloading under the AUSTRALAN road rules traffic act in any state ever.
Cheer
Glenn
Hi Glenn. Great to see that you're taking your weights seriously. Happy to answer any questions you may have, but even with your flash 3200GVM upgrade your car's rear axle carrying capacity is the problem.
You did in fact mention towball weight when you claimed, highlighted below, that tow ratings refer to towbar towing capacity. That statement us rubbish.
Please correct me if I'm wrong but I believe that your car's GCM still is 5900kg, (maybe only 5750kg) so IF you could EVER get to your 3200kg GVM (absolutely IMPOSSIBLE) whilst towing, your GTM could be maximum 2700kg. This equates to towing a van with an ATM of 3000kg, absolute maximum, and unattainable under "normal" conditions.
GVM upgrades are generally a waste of money for tow vehicles, but can be great if the vehicle is to be used as a touring vehicle.
The main problem for tow vehicles is rear axle carrying capacity, and you've forked out big dollars to gain a miserable 50kg? Why bother?
Happy to help you out of the wilderness with your weights, but at the moment you seem well lost? Best of luck. Cheers
P.S Again I would like to commend you for at least taking your weights seriously, but you seem to have been "advised" by people with only vested interests?
P.P.S Not disputing your assertion that "no passenger vehicle has ever been fined for overloading", but you no doubt realise that many insurance claims have been declined for that very reason. Not worth it. What's your life, or that of other motorists, worth?
-- Edited by yobarr on Thursday 23rd of March 2023 08:27:46 PM
Farmhouse said
08:44 PM Mar 23, 2023
Last comment from myself.
I have installed in the rear of the Mux Titan two drawer system with a Kings fridge drawer on top.
We did this so we can regulate and control our weight in the vehicle. This is so we can, if we choose to max the van out at 3000kg.
We. packed the fridge and the drawers with exactly(?)what we will carry with the van connected.
We then filled the vehicle with fuel, 2 persons, one dog etc etc. and went over a weighbridge.
We guessed the TBW at 260kg.
The GVM came in at 2730, so just snuck under the rateing of 2750. GCM is 5750, so we need some treeking, but close.
We can under Australian design road regulations have a GVM of 3200 kg, the new Certified GVM.
However we will never do that weight, due to the safety factor. We will stick to under 2700kg.
So
yobarr said
08:56 PM Mar 23, 2023
So
And I'll tell you for free that if your van's weight is 3000kg your towball weight is too low and that you're over your rear axle carrying capacity of 1650kg, and your setup is likely unsafe as your wheelbase is only 2845mm, from memory. Think "Yaw". Cheers
-- Edited by yobarr on Thursday 23rd of March 2023 09:00:57 PM
Possum3 said
08:26 AM Mar 24, 2023
Glenn, I'm uncertain where you got the information that no passenger vehicle has been fined for overloading/overweight - Check your source.
Regardless of legalities - Safety should be your main concern.
Farmhouse said
03:56 PM Mar 24, 2023
Safety is very important to me also, as it should be.
My sourse is very accurate, I would think this person would without doubt the best informed, best knowledge, most qualified person in Australia.
He travels world wide to assist big vehicle builders with warranty claims, companies like Toyota, Nissan, Ford, GMC, you name them and he has advised or assisted in court cases all over the world.
Will I name him, no I will not. Believe me this guy knows his stuff.
Seven sevens in aero naughtacal (I cant even spell it) engineering is not a bad start.
Do I bother him with this weight stuff? Not very often, but when I do he always knows his trade.
yobarr said
04:05 PM Mar 24, 2023
My source is very accurate, I would think this person would without doubt the best informed, best knowledge, most qualified person in Australia.
Unless he can can provide figures to support his assertion I am happy to say he's wrong. You no doubt have great faith in this chap's "advice", but this is LaLa land stuff. It's impossible to help people who refuse to learn. Cheers
P.S Nautical. What does seven sevens mean? Is it relevant to this discussion? I have no degrees relevant to this discussion, but I have lots of experience with weights. Experience always beats theory.
-- Edited by yobarr on Friday 24th of March 2023 04:19:35 PM
Farmhouse said
04:25 PM Mar 24, 2023
Honestly mate Your arrogance is outstanding. Seven. Sevens is the highest mark you can achieve.
How about you show me someone who has been fined for overloading a passenger car in Australia, I am sure you can scratch one up.
Another thing, feel free to admit you are wrong at least once, hell mate I do it every day, good for the soul.
Sorry admin, but fair dinkum enough is enough.
yobarr said
04:43 PM Mar 24, 2023
How about you show me someone who has been fined for overloading a passenger car car in Australia, I am sure you can scratch one up.
When outlandish unsupported statements are made regarding weights always I will respond. Try this story for starters. No doubt there are dozens - yes dozens - of other cases. Car was Prado, from memory? Cheers.
P.S Yes, there once was a time when, briefly, I thought that I was wrong, but I was mistaken.
What vehicle was it and was he charged for overloading the vehicle?
This is turning into some real fun here, hope we have an audience.
yobarr said
05:38 PM Mar 24, 2023
Farmhouse wrote:
Nah surely you can do better then this.
Could I respectfully suggest that you give up? You're clearly way out of your depth posting about stuff that you have little understanding of. Instead of ignoring help you might be better to heed good advice from those of us who know what we're talking about. Cheers
-- Edited by yobarr on Friday 24th of March 2023 05:40:55 PM
Sorry mate, very sad story. I hope the family have moved on after this horrible accident.
You have do some more research, still no passenger vehicle has been fined or charged with a OVERLOADED vehicle in Australia.
It is fine to concede, no one really cares.
yobarr said
06:39 PM Mar 24, 2023
Hmmm. And you reckon that a Prado is not a passenger vehicle? Surely having 5 seats, at least, would qualify this vehicle as such?
As for the family "moving on" did you not notice that there is no family left? This chap killed his wife and her son because he chose to overload his vehicle, despite him being a long- distance truck driver who perhaps should have known better?
Girlfriends are not necessarily part of "family" and don't count. Family gone. Dead.
Did you not notice that the van was overloadedby 800kg ?
Finally, I have no requirement to "concede" as I have provided only indesputable facts. Grow up. Cheers
-- Edited by yobarr on Friday 24th of March 2023 07:46:26 PM
Farmhouse said
06:52 PM Mar 24, 2023
The state of the family is not in question.
Where does the article say the VEHICLE was overloaded?
Where does it state he was charged with a ( let me try this again) a OVERLOADED VEHICLE?
Here is a hint for you..the regulation does not necessary apply to a tow vehicle. It also refers to the G VM of any passenger vehiclie in Australia.
-- Edited by Farmhouse on Friday 24th of March 2023 07:08:20 PM
Not sure if this is posted elsewhere.
As of March 9 2023 a Queensland registered tow vehicle GCM rating can be re rated if modifications have been carried out on the tow vehicle.
Please have a look at the following publication.
https://www.publications.qld.gov.au/dataset/queensland-code-of-practice-vehicle-modifications-qcop/resource/cc94c072-96d8-4b67-a3b2-0aa9433aea4f?inner_span=True
If unsuccessful then Google LS16 GCM rerating Qld
I think this might be the link that some are seeking
https://www.thegreynomads.com.au/towing-9/?fbclid=IwAR3p6zHk1b9wM9YzlmEsw4PqjvpIJjXk2LW7jL4zgNZMgZzExd6UcjaxrtU
lol whats a mux?
Oh dear Glenn, you are terribly confused. Tow ratings refer to the legal, but not necessarily safe, limit of the vehicle's ability to tow a trailer. It is generally accepted, and simple physics, that the towball weight should be at least 10% of the towed vehicle's ATM. This means that if your MUX is towing a 3000kg ATM van, your towball weight should be at least 300kg.. Because of your 1075mm TBO ( towball overhang, or distance from rear axle to hitch point) the actual weight applied to your car's rear is around 400kg (+/-) . Your car has a rear axle weight at TARE of at least 1080kg, so applying 400kg to the rear axle increases that weight to 1480kg. Rear axle capacity is only 1600kg, but tare is weight of the car with NO driver, NO passengers, NO luggage, NO spares, NO weight of actual towing structure, so NO HOPE. Your GVM upgrade, as always, is virtually a waste of money because your rear axle carrying capacity increases to only 1650kg. A HUGE 50kg! Why bother? However, if you do have that GVM upgrade you can now safely tow your 3000kg ATM van, ONLY assuming GCM upgrade which I doubt you'd have? Could you please supply all figures from your GVM upgrade so that I can give advice? Cheers
Cheer
Glenn
So
Did you not notice that the van was overloaded by 800kg ?
