Due to a design defect, the water pump can create a vacuum within the electrical area of the pump. This could cause liquid from the coolant system to permeate the housing of the water pump and damage the electrical circuitry which could cause a vehicle fire.
Note: In the event that the Engine Management Light illuminates, or smoke is detected, owners should stop the vehicle where it is safe to do so, turn off the ignition, evacuate the vehicle and contact your nearest retailer immediately.
Joda said
08:13 PM Feb 9, 2023
Bugger, I was looking at buying one!
04:24 PM Feb 10, 2023
At least it wasn't tens of millions of recalls.
peter67 said
11:01 AM Feb 11, 2023
And they come with pre historic lucas type "prince of darkness" electronics, see you tube vid "I bought a cheap Bentley"
I know there is a sub section but, at over $500,000.00 maybe the main area is better.
Bentley Motors Limited - BENTLEY Continental GT and Continental GT Convertible 2018 - 2019
Recall number - REC-005611
Affected units - 194
What are the defects?
