Hi I need to get a new shower head and looking for a good pressure shower head but with a high WELS number. Any help?
deverall11 said
06:31 PM Nov 11, 2022
Both are incompatible.
06:49 PM Nov 11, 2022
The shower head doesn't create pressure.
If you need more pressure the pump needs to be a higher pressure pump.
If you need volume the pump also needs greater capacity.
KJB said
06:58 PM Nov 11, 2022
Pressure and volume are two completely different things and use different measurements......KB
Possum3 said
07:42 PM Nov 11, 2022
Maz is your van the one in Avatar? It appears to be an Evernew. If so, give Richard a ring.
CONTACT DETAILS:
Evernew Caravans
20A Reserve Street,
Preston. Victoria 3072
(03) 9459 7516 info@evernewcaravans.com.au
Mein said
12:48 AM Nov 12, 2022
I've just bought the one below. It gives me the sensation of high pressure from my low pressure hot water service because the holes are microscopic.
If you want the sensation of high pressure. Our triple ARB compressor setup using a venturi air/water gun works well. The fine water droplets blasted out via 135psi air tank provides a feeling that you are being sand papered away.
The costs are about 90 amps while the 3 air compressors are running & the advantage is that the Perrier bottled water usage is 0.5 litres per minute.
The abrasive spray also cleans off brake dust on the wheels really well.
CONTACT DETAILS:
Evernew Caravans
20A Reserve Street,
(03) 9459 7516
https://www.ebay.com.au/itm/314117117773?hash=item4922d6d74d:g:z-sAAOSwcQljBGfK&amdata=enc%3AAQAHAAABIJeZuAV7iBizAuGlk8RDdKduqNNbUfrRs%2BwCiYm7p47mi1%2FggtQY4RuQqfG7P7xM6isfEhbheSgqmAMiSWfLMQ45BPiRSjKRWfOYawhqnwhYKE8I8%2BeK9IM0Jsfq08AEYAhc%2F5ky6NqFjGF7VgNh7om%2BJX99wxhGwk2xSHEZWzdKvh9mlND%2BZUOMpnzDEPpAfwMtqBzsEHDJg1Pog9fQr073bb7zs26j3vkm2Iuf9Ewvx14UQyBdE2bCWHxrDs%2FCJ%2BKZyEae3WDKU%2Bq%2BfmDPQ1x3vflLXfsxXvzf5PNx1Y7glJd717lQskPnwklziIjg2smvTIaU79D3LNivOJPS2e%2FdqZwsdooyGuj8jL1lgkWwVIpbPMX49UN5kNJmcqzeaA%3D%3D%7Ctkp%3ABk9SR8C1gO-MYQ
Just a friendly tip. You can cut all the crap off Ebay and Amazon URLs without affecting the target.
