The Sidchrome is a rotator as well as conventional ratchet. The handle will twist to rotate the bolt or nut if you are in a tight spot. The black ring rotates to change direction. Red button to easily emove socket.
What is the purpose of the ring on the step? And the lightweight chain that seems to disappear along with the red things?
Is it double purpose with a bucket to go underneath?
-- Edited by Are We Lost on Tuesday 20th of September 2022 05:33:15 PM
Ivan 01 said
07:22 PM Sep 20, 2022
It seems like it might be a bit uncomfortable having to sit on a chain.
Sit, I said.
I said Sit
Craig1 said
09:24 AM Sep 21, 2022
A W L, designed for a plastic bag, one time use, mainly for widdle stop, so the plastic chain is pretty soft, the red tags retain the bag. Also still can be used as original step .
Lucky we seem to got over the emergency stop thing.
KJB said
09:27 AM Sep 21, 2022
Craig1 wrote:
Just do not forget it is there and maybe full, when you move off.........
Sit, I said.
I said Sit
