Does anybody know of a product that will remove or reduce scuff marks from the Perspex windows?
I have tried Vuplex but not successful.
Thanks.
Dick.
12:32 PM Jul 29, 2022
Brasso or toothpaste & touch of water & elbow grease. Don't use a mechanical polisher. Get the slave to do it!
You will not remove the scratches, but simply polish them so they are less visible. A problem I had with architectural model acrylic covers to tidy them up. It does come up well, but it is based on elbow grease input.
Joda said
05:16 PM Jul 29, 2022
Headlight restoration kit from supercheap, fixed my 40 year old motorbike fairing screen, has a polish & spray on sealer,
Joda
littledick said
05:02 PM Jul 30, 2022
Thanks for reply. I thought of toothpaste and brasso but maybe a bit harsh. I might check the headlight restorer.
It's more of a graze from a tree branch.
Thanks again.
Dick.
Cisco kid said
09:08 AM Jul 31, 2022
Tree branches are a nuisance , often happens after a long day behind the wheel . Recently scraped paneling on side of our van
Try all of the above remedies though
I have taken to using a reciprocating saw to deal with nuisance branches ( good source of firewood)
littledick said
09:33 AM Jul 31, 2022
Cisco kid wrote:
Tree branches are a nuisance , often happens after a long day behind the wheel . Recently scraped paneling on side of our van Try all of the above remedies though I have taken to using a reciprocating saw to deal with nuisance branches ( good source of firewood)
Unfortunately, the trees are at the front of ours and the neighbours house.
I try to keep them trimmed, being in an over 55s lifestyle village, the roads are probably wider than you would normally come across.
I try to keep as close to the gutter on entry to the front of our house. Went a bit close on one occasion. The things are still growing. I consider the original landscaper planted the majority in the village too close to the gutters
and overhang the roads considerably. Another word to our Assoc Committee needed.
Dick.
08:30 PM Jul 31, 2022
Rub with 600grid wet sand paper block and detergent. Then rub with cutting compound .
-- Edited by Aus-Kiwi on Monday 1st of August 2022 06:11:53 PM
RichardK said
12:00 PM Aug 1, 2022
I believe Novus Compound is good, although I haven't tried it myself others have recommended it to me, it is on my list of products to get when I get around to it.
It is on the net, the link is too long to put up just search Novus Compound
Cheers RichardK
-- Edited by RichardK on Monday 1st of August 2022 12:02:06 PM
bobsa said
03:19 PM Aug 2, 2022
I had very bad scuffs on all my widows
while brasso did help ,in the first it did not get them all out
I ended up sanding the scratches out
I started with a 2000 grit wet and dry 125mm hook and loop pad
I then wrapped around them a foam sanding block
( those black ones from Bunnings ) this gave me the grip to hold the disc
I then progressed to a 3000 grit wet and dry hook and loop 125 disc
this i did wet with a little dishwashing detergent
finally finished with a complete rub over with a fine car polish
Thanks.
Dick.
Thanks again.
Dick.
Dick.
RichardK
they now look like brand new
bob
125 mm 3000 grit Sunmight D532 Wet & Dry Hook & Loop Disc
