Soooo..the po of my slide on installed a 90L water tank but with no means of measuring its level.
What are my options to do so?
The lower end has a take off to a regular pressure pump.
The tank itself is accessible for service but otherwise hidden inside a void as is the pump.
My schoolboy idea is a sight tube using a new hole in the tank base and brought out to somewhere it can be seen - probably using a flexible tube over vertical scale.
Other wisdom?
Dave
Ivan 01 said
09:07 PM Jul 19, 2022
Hi OKA,
Have a look at these.
They measure accurately the amount of water used in comparison to the volume calibration you set on installation.
Much easier than site tubes but it will cost a bit more.
Other wisdom?
Dave
Hi OKA,
https://www.topargee.com.au/water-gauges
Thanks Ivan looks just the thing!
