Hi all been thinking about buying a 200 ah lithium battery in particular a kings .. or enerdrive ? with so many on sale need help to make that decision ? Anyone out there that can do a recommendation ....
thanks
yobarr said
12:59 PM Jun 4, 2022
thanks
Enerdrive is a VERY good brand that I considered before buying 8x90ah Victron. Kings is, to me, an unknown quantity although I will say that their spotlights work well on my car, Cheers
goldenyears said
01:01 PM Jun 4, 2022
thanks yobarr
01:15 PM Jun 4, 2022
Amortised quality is more economical in the long run.
goldenyears said
07:09 AM Jun 5, 2022
will stick with enerdrive bit expensive but perhaps better in long run ...
yobarr said
07:57 AM Jun 5, 2022
Good decision. Cheers
Lozza56 said
08:12 AM Jun 5, 2022
I got 170ah Lithium battery from Aussie Batteries, all going great, set up with solar panel on top of my 200, always at 100%
Kebbin said
08:49 AM Jun 5, 2022
Lozza can I ask how long have you had the Aussie Lithiums installed?
Dick0 said
11:48 AM Jun 5, 2022
Hi goldenyears,
Cheaper to get two x 100ah, or similar, than single 200ah.
Example...
2 x 135ah $503.91ea ($1107.82 for 270ah).
Four years warranty. Connect up to four parallel/serial.
My concern with so many brands out there the choice is the hardest !!
-- Edited by goldenyears on Sunday 5th of June 2022 02:07:01 PM
goldenyears said
02:09 PM Jun 5, 2022
Thanks dicko will have to check all that out ..
My concern with so many brands out there the choice is the hardest !! cheapest not always the best ...
TimTim said
07:50 PM Jun 5, 2022
thanks
08:07 PM Jun 5, 2022
Dick0 wrote:
Hi goldenyears,
Example...
Nice batteries for sure, but out of my camping price range, and specs more for off grid home base systems utilizing high end 240V inverter multi appliance energy usage.
Paulp said
05:16 PM Jun 7, 2022
Look at Renogy 200amp specs seem ok
TimTim said
10:33 PM Jun 7, 2022
$2399 is a a bit rich for a 200Ah Enerdrive battery.
8 x 105Ah A grade cells and Daly BMS can be bought from China for about $611 + shipping. Given that these companies can buy them cheaper that will leave plenty of $'s for a case, labour and profit.
Or you can buy the battery made up $624 + Shipping.
-- Edited by TimTim on Tuesday 7th of June 2022 10:43:20 PM
Lozza56 said
08:11 AM Jun 8, 2022
I've had my 170ah Lithium battery for only 2 months, put it in back on my Landcruiser with a 210w Solar panel on car roof, plus a Redarc charger from 2nd battery.
main use is my 85lt car fridge, got sick and tied of camping, having no power from 2nd battery after few days, so yeh, good set up, solar charges initially, then Redarc takes over if no solar. point is we've all had fridges not work, just want cold drinks and meat etc in car fridge, next will be 2 Lithiums in caravan
thanks
thanks yobarr
Hi goldenyears,
Example...
135Ah 12V Lithium Iron Phosphate Battery LiFePO4 Deep Cycle Solar BMS RV Recycle 602353257669 | eBay
12.7kg is extremely light for 135AH.
Hi DickO,
Reading the specs of those batteries, the maximum continuous discharge current is 50A.
In my opinion, a battery of that size should have at least 100A continuous discharge.
Just my opinion...
Agreed. Garbage product. You get what you pay for. Cheers
Hi w & p,
Same specs as your batteries only higher capacity and slightly heavier. 50ah continuous discharge works for me.
Hi yobarr,
And your recommendation, as an example, of 135ah LiFePO4 brand and cost is....?
I suppose the one redeeming feature is that it will float 22% above the water.
It does pose the question, why so much space in the box?
Whereas a Victron lithium battery would sink quickly without trace!
Hi W,
And your point is?
Battery vs probably no battery!
Hi W, And your point about floating batteries is...?
Especially when it comes to sinking batteries.
And just for curiosity, how many 100ah-135ah Victron LiFePO4 batteries are in your system?
-- Edited by Dick0 on Monday 6th of June 2022 04:42:39 PM
This tread will tell you:
https://thegreynomads.activeboard.com/t65231112/custom-6x20-watts-solar-setup-with-mppt/
http://www.lowenergydevelopments.com.au/batteries/LithiumBatteries
Tells me it's a bits of this and a bit's of that.
And maybe the batteries are sinkable.
www.alibaba.com/product-detail/EV-12V-200ah-lithium-lifepo4-solar_1600145617707.html
