I have just removed my Baby Q and galvanised steel slide from the front boot of my JB Gator caravan. This is in the interests of reducing the tow-ball weight. The Baby Q is held securely on the slide by slipping into strong brackets with spring latches. The BBQ is quick to remove to set up safely away from the van with a 3 metre gas hose with bayonet fitting. The slide is 582 mm wide x 80 mm high x 720 mm long when closed. With the Baby Q in place it is 450 mm high. The slide travels 600 mm.
The slide is definitely for sale at $100. Will include the Baby Q for an extra $200 ($300 total). Pick up from Bentleigh, Victoria, or will deliver FOC within 20km radius.
