hi Ryco have recently modified there c/cans Old Rcc 350 New Rcc351
1st mod ****filter has one end [bottom ] 90 % enclosed Why I suspect to restrict oil slosh from being sucked into outlet which is at the other /top end of filter
2nd mod Outlet located at top of filter has alot larger baffle WHY,, To prevent excessive oil from being sucked thru c/can ie slow the air so it can return more oil to storage area
3rd mod pressure regulating valve located on the top out let Function ,, to protect filter media against un needed pressure waves problem ,, this restricts flow solution ,, the later Rcc has this removed
Old Rcc 350
New Rcc351
1st mod
2nd mod
3rd mod
