Go for the dry end, or the one with nothing on it. Conversely, get your own stick.
yobarr said
03:27 PM Dec 14, 2021
Wouldn't matter if gloves were being worn,would it? Cheers
Craig1 said
03:28 PM Dec 14, 2021
One member on here uses those little " bones" for his fire. May not be any sticks?
iana said
03:34 PM Dec 14, 2021
Pick the stick up and smell each end, the rest should be self explanatory.
Bobdown said
06:46 PM Dec 14, 2021
Depends if their $hit don't stink, or it might be 'sticky' poo.
This post should be flushed away.
SoloMC said
07:10 PM Dec 14, 2021
I've never had solids that needed poking down any dump point
if the additive you use works properly, there are no solids in your crap.
if so, maybe a change of diet to ensure that your stools are soft
re the stick, give it a lick to see if you can tell which end to use? :)
Heres a question that would be on everyones mind.
Yes, The stick is obviously there to poke away any excess toilet paper or Poo BUT
Which end of the stick is used to poke with and which is used to hold it with.
I like it!!
But...
Logic tells me, that the sticky end of the stick, is the end I would use for poking
Why would you use a stick when the hose would do the job?
ever heard the expression ****abrick , you might need a bit of vivid imagination and think of extreme constipation
It might be to scrape down spider webs.
Sh-t a brick and fart a crowbar was often heard many moons back.Cheers
