Well, I know what the spear is it is a harpoon for seals.
Craig1 said
05:19 PM Nov 23, 2021
Well that solves one question, safe on dry land now, a long way from the sea.
Bicyclecamper said
10:53 AM Nov 24, 2021
The threaded cap on the left, I think, is from 20 gallon fuel/oil drums, I have also seen the handle on the bottom right, but can't remember where, and what it is for. The brass nuts, are off oil lines, have seen them on boilers. *** The brass handle, looks like it is a brake handle for coal powered steam trains, just remembered where I did see that.
-- Edited by Bicyclecamper on Wednesday 24th of November 2021 10:59:13 AM
Craig1 said
11:46 AM Nov 24, 2021
The bottom right one is part of a door/hatch hinge I believe. Top on left, you may be right ? we used to have steam trains come into Stanley.
rgren2 said
11:50 AM Nov 24, 2021
The split link is off a harness, its a quick latch unlatch joiner.
Craig1 said
01:09 PM Nov 24, 2021
Fishermen used them to easily lengthen a cray pot line when they moved to deeper water, very occasional failure, so you lost the craypot and potential contents. But very convenient and easier to undo than a mongrel wet knot in sisal rope.
Haji-Baba said
04:01 PM Nov 24, 2021
The brass chain link with the v cut was called a Sister Clip on sailing boats.
Used to assist quick release of sails sheets etc.
The block of wood that the brass fittings are mounted onto is very similar to a piece of Rose Mahogany I sold at a garage sale some years ago.
Even down to the sap line in the bottom edge.
Have fun Haji-Baba.
Ps. Couldn't be, the original post from Albury, probably river red gum.
-- Edited by Haji-Baba on Wednesday 24th of November 2021 04:04:27 PM
Craig1 said
05:49 PM Nov 24, 2021
Sorry Jeff, only stained pine , colour is Rosewood, a left over bit of project from daughters highschool, some 23 or 4 years ago. Thanks for the name of clips, could never remember.
06:45 PM Nov 24, 2021
G'day Craig, hope you are both well and avoiding all those germs up there?
Now, are you sure you have named those things right? They bon't look anything like 'bibs' and don't look like any 'bobs' I know.
Craig1 said
07:56 PM Nov 24, 2021
Better go to specsavers Chief, the harpoon could certainly fasten any BIB, the little nuts could belong to Robert.
Only a couple of cases at the moment perday, or none yesterday
Have fun Haji-Baba.
